Client Not Achieving NAT Type OPEN
SheedaBhaii
Post by SheedaBhaii » Sun Aug 13, 2023 7:08 pm
So Basically, I hosted a Public VPN via VPNGate. The Client got the static Public IP but his NAT Type didn't get OPEN.
I Tried both Enable Secure NAT and Disable Secure NAT. What could be the problem?
Re: Client Not Achieving NAT Type OPEN
Post by solo » Mon Aug 14, 2023 8:32 am
For security reasons you should not bridge the VPNGATE hub, therefore "Disable Secure NAT" is not an option. The clients are not concerned with your server's NAT type anyway.
