bestsamp
Post
by bestsamp » Sat Aug 19, 2023 3:33 pm
Can someone explain / help how do i connect to a vpn from
https://www.vpngate.net/en/ using command prompt? I just can't figure it out. I tried something like this
vpncmd 163.182.174.159:443 /server /hub=VPNGATE /password=vpn
but it's saying that the password is wrong?
Access has been denied. Possibly the password is incorrect, or perhaps you are connecting by an incorrect admin mode. You can try inputting the password again. To cancel, press Ctrl+D.
Password:
Post
by solo » Sat Aug 19, 2023 3:48 pm
1. add
host: public-vpn-185.opengw.net/tcp
port: 443
vhub: VPNGATE
user: vpn
pass: vpn
2. connect
vpncmd localhost /client /cmd AccountConnect public-vpn-185
bestsamp
Post
by bestsamp » Sat Aug 19, 2023 3:58 pm
solo wrote: ↑Sat Aug 19, 2023 3:48 pm
1. add
port: 443
vhub: VPNGATE
user: vpn
pass: vpn
2. connect
I understand now, but I had just one more question is it possible to add the vpn configuration from command prompt aswell?
Post
by solo » Sat Aug 19, 2023 4:26 pm
