Installing Softether on Mikrotik
Keyoumars
Hi, I'm from Iran and the only thing that works here is Softether and V2ray. I wanted to see if it is possible to install Softether on Mikrotik?
Re: Installing Softether on Mikrotik
Yes, but first install OpenWrt on it.
Frost751
It's great that you've found Softether and V2ray to be useful. Regarding your question about installing Softether on Mikrotik, unfortunately, Mikrotik routers typically do not support Softether VPN natively. Mikrotik routers generally use their own RouterOS, and Softether is a separate VPN solution that typically runs on a Windows or Linux server.
adroman
Hey, guys!
Has anyone managed to configure Mikrotik SSTP connection to SoftEther ?
Mikrotik SSTP client => SoftEther VPN Server?
shakibamoshiri
https://www.vpnusers.com/viewtopic.php? ... tik#p98303
It depends on
- SE version
- and ISP net
to work properly
