Softether configuration for an iPad
Asiguenas
Post by Asiguenas » Tue Sep 05, 2023 8:06 pm
hi everyone I've been trying to configure we have to an iPad but nothing works. i have the softether offical step for the OS configuration but it doesnt show in detail how to set up it
Re: Softether configuration for an iPad
Post by solo » Tue Sep 05, 2023 11:02 pm
https://www.vpngate.net/en/howto_l2tp.aspx#ios
It does not get any clearer than this.
Fernando
Post by Fernando » Tue Sep 19, 2023 9:25 pm
Try to use an OpenVPN connection.
That worked for me on a mac-mini
- Install OpenVPN Client
- Enable OpenVPN on server and generate the OpenVPN config-file:
  • · Connect to your SoftEther server
    · Push button 'OpenVPN / MS-SSTP Setting' (down right corner)
    · Check 'Enable OpenVPN Clone Server Function'
    · Push button 'Generate a Sample Configuration File for OpenVPN Clients'
- That gnerates a zip flle with 4 files. We need the file that finishes with ..._l3.ovpn
- Open OpenVPN Client App
- Import file
- Put user and password
- When ask you for certificate, push 'Continue'
