are using softether openvpn. I'm currently connecting with ID and Password (user authentication)
I want to access without id, password.
availability and
Please also tell me where to modify the ovpn file option
Or is there a way to enter your ID and password in advance in the ovpn file and access it without a login window?
I wonder how to get rid of ID and password through user authentication
dna2073
shakibamoshiri
Re: I wonder how to get rid of ID and password through user authentication
1. make a certificate for that user via "vpncmd" or SE GUI (cert + key)
2. load the cert for that user (user authentication will change to [2]) -- certificate authentication
3. add the cert and key at the end of you ovpn file
NOTE
this is possible in SE developer version not stable one
Thanks @solo
NOTE
Thanks @solo
Last edited by shakibamoshiri on Wed Sep 27, 2023 5:55 am, edited 1 time in total.
