Client unable to reach target server on other network
Amit
Post by Amit » Sat Oct 14, 2023 9:09 pm
Setup.
Vpnserver on virtual machine with two nic card
ens3 ip add: 192.168.47.225/24
ens4 ip add: 10.207.1.2/29 (specifically created for local bridge)
Nic card assigned to local bridge ens4.
Virtualhub setting
Securenat enabled with virtual dhcp and virtual nat is disabled.
Virtual DHCP scope 192.168.30.0/24
Virtual dhcp interface ip 192.168.30.1
Physical L3 device config
Physical Layer3 device vlan interface IP 10.207.1.1/29
Physical layer3 device vlan interface IP 192.168.77.254/24.
My vpn client connects properly and getting the IP address from the DHCP scope in the range of 192.168.30.x
But i am unable to reach server which is on the network 192.168.77.0 nor am i able to reach 10.207.1.1, what i feel is the traffic is not reaching localbridge. I am stuck here, unable to understand what to check further. Any help from forum members will be appreciated. I have attached some of my config snaps.
Re: Client unable to reach target server on other network
Post by solo » Sat Oct 14, 2023 10:36 pm
