Build Version not shows properly after update
HellSpawn
Post by HellSpawn » Mon Dec 04, 2023 5:48 pm
my only problem is that i can not show new Version in SoftEther VPN Manager Server (windows app)
in putty via ./vpncmd command about i can see the new version but in windows app show only the old one:
is there any way to show the new Version in VPN Manager Win App?
Re: Build Version not shows properly after update
Post by solo » Mon Dec 04, 2023 9:01 pm
That's the Command Line Management Utility version number, not the server's. Run ".../cmd ServerInfoGet".
