i am using openvpn over softether . but the videos loading very very slow in telegram and in same time there is no problem loading videos in istagram !!
and updating application in ios is too slow to
in case of compare when using openvpn over mikrotik cant see these problems !
has anyone same problem ? maybe a solution ?
media loading e.x in telegram or updating app in ios problem
boby_turk
Re: media loading e.x in telegram or updating app in ios problem
When you VPN 255 simultaneous users, you can expect all sorts of problems. Upgrade your hardware and network connection.
boby_turk
this problem appear in every conditions . even just 1 user connected to server . video loading in telegram and updating ios apps are so slow . but instagram works well
this is private use service made with cascade connection between inside and outside the country and maximum 10 people get online in the same time
the 255 users problem has solved by editing subnet mask to 255.255.254.0 and there was no cascade connection , just 1 server inside country authenticating user to get access to files . but this problem shown when using 2 servers with cascade connection
boby_turk
i test every conditions and realized when using Stable Edition speed is normal and good . but when you are using Develepor editin with same as same configuration speed comes down nearly 60%
anyone has any idea for the reason ?
