Go Out To internet from Remote site
absolutita
Post by absolutita » Fri Jan 05, 2024 6:08 am
Hello all,
just discovered this software and it seems amazing.
I would like to get your advice for the following need.
I have two sites SITE A and SITE B.
SITE A
here the hosts are connected to a consumer modem with dynamic public IP.
the local LAN is 192.168.1.0/24
IPs to the host in the LAN are assigned by the DHCP running on the modem
The default gateway of the LAB is .1 that is the modem
SITE B
this is like the site A, there is a consumer modem with dynamic public IP and the local LAN is 192.168.1.0/24.
The default gateway of the LAB is .1 that is the modem.
I need the hosts of site A to go out of internet from the modem in SITE B.
What would be the best approach/setup?
thanks
Enrico
Re: Go Out To internet from Remote site
Post by solo » Fri Jan 05, 2024 6:52 am
On B enable SecureNAT with defaults and... that's all.
absolutita
Post by absolutita » Fri Jan 05, 2024 7:35 am
thanks @solo
I would assume in my case i need to configure a LAN-to-LAN VPN right?
Post by solo » Fri Jan 05, 2024 8:21 am
If your only objective is to "Go Out To internet from Remote site" then do as prescribed above and don't worry about VPN naming scheme.
