hi all opened issue #1942 on github for a wifi network adapter not seen by Softether in the local bridge UI.
note: wireshark can sniff traffic on that device
RTL8822CE 802.11ac not seen #1942
Re: RTL8822CE 802.11ac not seen #1942
It does not support promiscuous mode and is not acceptable.
Look, you need no bridge anyway and all you have to do is install SE and click "Enable SecureNAT" as discussed earlier https://www.vpnusers.com/viewtopic.php?f=7&t=68769
