I had the server v4.42 built, installed and working nicely on OS X 10.9 and 10.11 El Capitan. .install.sh, then vpnserver start, then vpncmd, then caps and hublist, all OK.
I installed it on Mojave and can't get it to work !
Configs :
- All 10.9 10.11 and 10.14 configs are VMWare Fusion 11.5.7 VMs.
- All 3 VMs have their own IPv4
- SIP seems not to be the problem as it is disabled on 10.14.
- Full disk access is allowed for vpnserver, vpncmd (and hamcore.se2 in case it is needed).
- I have tried both sudo su before manual launch in Terminal and placing a successful plist in the LaunchDaemons folder with a Restart.
The vpnserver process starts and shows in Activity monitor but it does not operate properly on 10.14 :
- The log folders are not created.
- The config file is not created.
- The server can't be reached on any port.
- No ports related to the vpnserver are shown by a port scan using Network monitor (but they show on 10.9 and 10.11).
- At last, chmod -R 777 on the whole vpnserver folder changes nothing (before you ask ;) )
I have seen posts related to successful use on macOS releases newer than 10.14, so it should work…
Does anyone know what I did wrong ?
SoftEther VPN Server unreachable for admin on macos Mojave
DMA
Re: SoftEther VPN Server unreachable for admin on macos Mojave
Check your old working VM backup image on the new host.
DMA
All 3 installs on VMs are fresh installs. When it failed on 10.14, I tried on older OS releases.
- The log folders remain the same as they were on the 10.11 : no log file is created by the launch on 10.14. So, no way to check what's going wrong with the logs (same as the original 10.14 install).
- The server remains impossible to admin (Error occurred. (Error code: 1) Connection to the server failed. etc.) when trying to connect with vpncmd (same as the original 10.14 install).
- No ports are opened by the vpnserver (same as the original 10.14 install).
Copying the 10.14 install in place of the 10.11 install on the 10.11 VM :
- The log folders missing on 10.14 are created and the log files are created.
- The vpncmd can reach the vpnserver as expected, and the caps and hublist commands are OK.
To sum it up : the working 10.11 install fails on the 10.14 (as the original 10.14 build), and the failing 10.14 install works on the 10.11 (as far as my testing goes).
Copying the 10.11 install in place of the 10.14 install on the 10.14 VM :Check your old working VM backup image on the new host.
Try DE, it may resolve the issue and has new features to offer https://github.com/SoftEtherVPN/SoftEth ... le-edition
DMA
Thank you for the suggestion.
Trying DE (having DE to work reliably for the company who asks me for a production deployment or just using DE to find out what goes wrong with the stable release on macOS 10.14+ built) means an unpredictable number of work hours that they won't pay for, I mean, by far!
Sorry… some day, maybe.
Thanks again, anyway.
