Create a server in my office PC
Locked
joaopa
Post by joaopa » Fri Jan 19, 2024 3:12 am
In my office, I have a PC under linux. I have root privileges in my PC. My PC is in a local network with a static address (10.9.1.15).
I have internet access through a proxy (proxy address is 10.3.1.251). I am not administrator of the whole network. Only of my computer.
Can I create a vpn server in my PC that can be accessed from my home? I would like to use my office PC remotely from m y house.
If it is possible, how to achieve that?
Thanks in advance for any advices.
Re: Create a server in my office PC
Post by solo » Fri Jan 19, 2024 9:26 am
Yes, this proxy-only scenario is achievable with a "reverse" vpn server approach:
- at home install both SoftEther server and client connecting to it via localhost
- from work connect to it via the proxy
- then home-work L2 connection will be available
If your home internet connection is limited, use SE VPN Azure address.
joaopa
Post by joaopa » Sat Jan 20, 2024 3:42 am
That means that I can not use my office desktop as a vpn server, right?
Locked
