I have SoftEther configured as a Local Bridge (L2) on Windows.
I'm using MS's builtin SSTP client.
When connected, I can PING resources on the VPN target's network including the printer. But I can't print to it. When I use the Windows Add Printer wizard, it seems no matter which option I choose, it doesn't see the printer/won't add the driver.
Again I can ping the printer on the target VPN.
Any ideas?
Can't print to Printer on VPN'd LAN
Re: Can't print to Printer on VPN'd LAN
It will work with SE client.
Bob Bertrand
I need to use Windows builtin SSTP as I can't install programs on the client.
When a remote user VPN's into Softether. using the Windows built in SSTP client and SoftEther is set up using L2 (Local Bridge), bridged to a real Ethernet adapter, I can ping my printer by FQDN or by IP Address. But when I try to do a Windows Add Printer, no matter which option I choose, it doesn't see my printer.
Catch 22.
Are you sure about it? I'm asking because if you drop this "wizard" and choose the manual option everything, including automatic driver transfer over SSTP, works fine.Bob Bertrand wrote: ↑Fri Feb 02, 2024 9:50 pmWhen I use the Windows Add Printer wizard, it seems no matter which option I choose, it doesn't see the printer/won't add the driver.
But if you insist on the wizard then SE client is necessary.
Bob Bertrand
Let me try manual again. Which manual option did you try? Sorry for bothering.
Bob Bertrand
Ignore my previous post - the graphics you posted loaded 10 seconds after I posted - let me try them.
