Openvpn help
khuramrr
Openvpn help
Post by khuramrr » Mon Feb 19, 2024 5:37 am
Hello everyone.
softether newbie here, everything works as documented, awesome product, really appriciate devs.
need help connecting android client. i did generate openvpn config, and yes manage to connect to server as well. but i cannot pass any traffic, as session keep dropping. with error "session invalidated: keepalive_timeout"
its about my self hosted softether, yes connection is made, IP is assigned, even shows openvpn is connected. but when trying to pass traffic gets error.
below are my config for openvpn and client side logs
OpenVPN Config
dev tun
proto udp
remote xxx 1194
cipher AES-128-CBC
auth SHA1
resolv-retry infinite
nobind
persist-key
persist-tun
client
verb 4
auth-user-pass
<ca>
-----BEGIN CERTIFICATE-----
xxxx
-----END CERTIFICATE-----
</ca>
client side error before connection get dropped
[Timestamp] Session invalidated: KEEPALIVE_TIMEOUT
i have already tried passing --keepalive and setting keep alive to "keepalive 10 120"
on server i have tried to disable "Keep alive internet connection" also trying vpn_config file.. nothing is there.
any help?
Re: Openvpn help
Post by solo » Mon Feb 19, 2024 6:28 am
Can it connect properly to any server from https://www.vpngate.net/en/howto_openvpn.aspx ?
If not, change it.
khuramrr
Re: Openvpn help
Post by khuramrr » Mon Feb 19, 2024 7:13 am
hello, its my self hosted vpn, i have just edited above as well.
also am able to connect, i get IP and everything else... just when try to send traffic i get disconnected.
