Multipath Link reliability Support?
wllim
Post by wllim » Mon Feb 19, 2024 5:40 pm
Does Softether support multipath to achieve link reliability between clients and server?
Please provide some guidance or reference for such configuration
Re: Multipath Link reliability Support?
Post by solo » Mon Feb 19, 2024 9:03 pm
wllim
Post by wllim » Tue Feb 20, 2024 12:24 am
Solo, thanks for replying to my question.
The scenario I aim to achieve is as follows:
Device A has two network connections, Wi-Fi and 5G, with Wi-Fi set as the primary connection and 5G as the backup for connecting to the VPN server. When the device moves out of range of Wi-Fi coverage, it would seamlessly switch to using the 5G network to maintain connectivity with the VPN server. The objective is to ensure continuous VPN connectivity even when transitioning between different network coverage areas.
Is this scenario supported by SoftEther?
Post by solo » Tue Feb 20, 2024 1:05 am
It is up to the device to arrange network fail-over. Then, net apps may or may not maintain their connections.
