I'm very newbie in IT skills, so i hope you can use easy words so that let me understand...
Anyway, after install SoftEther, i cannot see my list of connectable wifis in my windows..
Although it can automatically connect to my wifi, but i cannot see others usable wifis..
Can anyone give me any solutions?
but with easy words.. (i even don't know how vpn is activated, i just know it is a tool..)
+)i have already tried through "device manager". I re-installed my LAN's driver, or re-activated my LAN device, it temporarily fixed("fixed" means, whenever you want, you can see the list of wifi), but not permanently..)
Can't find wifi networks
csh0930aa
Re: Can't find wifi networks
It has nothing to do with SoftEther.
Click here https://duckduckgo.com/?q=windows+blank+wifi+list
csh0930aa
i'm totally sure that this is related to softether VPN.
Because my 2 ASUS notebook's wifi list is blanked just after install the softether vpn.
i think it is related with the process that inventing VPN adapter when you connect to other servers.
i just researched and found that
netsh wlan set autoconfig enabled=yes interface="Wi-Fi"
is effective in cmd, but not permanently..
can anyone give me other solutions?
csh0930aa
I don't know if this information is useful...
i put this in cmd,
netsh wlan show networks
and shows
Interface name : Wi-Fi
Visible networks cannot be displayed because auto
configuration has been disabled on the interface.
is this related to problem solvings?
i put this in cmd,
and shows
Where did you get it and what version? Do sigcheck on your installation. For reference, here is sigcheck on the latest RTM softether-vpnclient-v4.42-9798-rtm-2023.06.30-windows-x86_x64-intel.exe
sigcheck -e "C:\Program Files\SoftEther VPN Client"
Sigcheck v2.90 - File version and signature viewer
Copyright (C) 2004-2022 Mark Russinovich
Sysinternals - www.sysinternals.com
c:\program files\softether vpn client\installer.cache:
Verified: Signed
Signing date: 1:11 PM 30/06/2023
Publisher: SOFTETHER CORPORATION
Company: SoftEther VPN Project at University of Tsukuba, Japan.
Description: SoftEther VPN
Product: SoftEther VPN
Prod version: 4, 42, 0, 9798
File version: 4, 42, 0, 9798
MachineType: 32-bit
c:\program files\softether vpn client\vpnclient.exe:
Verified: Signed
Signing date: 1:09 PM 30/06/2023
Publisher: SoftEther Corporation
MachineType: 32-bit
c:\program files\softether vpn client\vpnclient_x64.exe:
Verified: Signed
MachineType: 64-bit
c:\program files\softether vpn client\vpncmd.exe:
Verified: Signed
MachineType: 32-bit
c:\program files\softether vpn client\vpncmd_x64.exe:
Verified: Signed
MachineType: 64-bit
c:\program files\softether vpn client\vpncmgr.exe:
Verified: Signed
MachineType: 32-bit
c:\program files\softether vpn client\vpncmgr_x64.exe:
Verified: Signed
MachineType: 64-bit
c:\program files\softether vpn client\vpninstall.exe:
Verified: Signed
MachineType: 32-bit
c:\program files\softether vpn client\vpnsetup.exe:
Verified: Signed
MachineType: 32-bit
c:\program files\softether vpn client\vpnsetup_x64.exe:
Verified: Signed
MachineType: 64-bit
