Connecting to Internet via Softether on Linux(Openwrt)
BG8LRR
Post by BG8LRR » Mon Mar 04, 2024 6:46 am
In this network only port 8080 is allowed. I set up a Softether Server on a home server, and connected to it
After setting the priority of adapters, I can connect to Internet with the IP of the server on Windows PC.
However, when I try to set this up on my router(Openwrt/Linux), I cannot connect to the Internet.
I've created a virtual adapter and obtained IP address by using "dhclient".
I never used VPN before. so if you can help, please keep answers straightforward.
BG8LRR
Re: Connecting to Internet via Softether on Linux(Openwrt)
Post by BG8LRR » Mon Mar 04, 2024 1:28 pm
hey solo, thanks so much for your reply! There's still something I didn't get the point. In thread it says <server address> and <default GW>. I use a wireless connection, which gateway is 172.22.79.254, and connected to vpn server at 113.*.*.189. Should I exec
sudo ip route add 113.*.*.189 via 172.22.79
254
and delete default?
If so, I already tried that, didn't work :(
Post by solo » Mon Mar 04, 2024 10:24 pm
route -n
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         10.0.2.2        0.0.0.0         UG    0      0        0 enp0s3
10.0.2.0        0.0.0.0         255.255.255.0   U     0      0        0 enp0s3
~~~ SE client connect to VPN Gate ~~~
netstat -tapn
tcp        0      0 10.0.2.15:33248         219.100.37.193:443      ESTABLISHED 	//a VPN Gate server
ip route add 219.100.37.193/32 via 10.0.2.2
ip route del default
dhclient vpn_vpn
route -n
0.0.0.0         10.245.254.254  0.0.0.0         UG    0      0        0 vpn_vpn
10.245.0.0      0.0.0.0         255.255.0.0     U     0      0        0 vpn_vpn
219.100.37.193  10.0.2.2        255.255.255.255 UGH   0      0        0 enp0s3
curl ifconfig.me
219.100.37.245		//the VPN Gate server's IP
BG8LRR
Post by BG8LRR » Wed Mar 06, 2024 10:51 am
hi solo!
Thanks for your reply! When I come to 'netstat -tapn', I found no entry that matches my vpn gate. As field 'Program Name' says, a process with name 'vpnclient' connected to 127.0.0.1. I have no idea about the reason (never used a local proxy)
Post by solo » Wed Mar 06, 2024 11:29 am
host: public-vpn-185.opengw.net
port: 443
hub: VPNGATE
user: vpn
pass: vpn
This is the 219.100.37.193 server. Use it for tests. Check on OpenWrt forum for more info.
BG8LRR
Post by BG8LRR » Wed Mar 06, 2024 2:00 pm
Thank you so much! I can use internet on my router now. Now I can dive into the next problem: all lan device are not connected to internet.
Anyway, thank you so much on helping me solving this problem!
