are there any home routers that can run Softether VPN Server natively?
I have a Ham radio station that is Ethernet based and would like to be able to use Softether as a tunnel back to home where my Radio station is located with out using a tethered cell phone with the VPN enabled when traveling, My Remote Radio doesn't have the capability to add a VPN service.
Thank you B Mills
Re: home routers that can run Softether
Yes, routers compatible with OpenWrt.
