Every hour all connections are lost
firefly
Post by firefly » Fri Apr 05, 2024 8:21 am
Hello.
I installed SoftEther on FreeBSD.
I have 2 connections from different routers (Mikrotik):
HAP-AC2: L2TP/IPSEC
LHG-R: SSTP
How to fix it ?
Re: Every hour all connections are lost
Post by solo » Fri Apr 05, 2024 8:46 am
Analyze SoftEther, FreeBSD and Mikrotik's logs.
firefly
Post by firefly » Fri Apr 05, 2024 9:00 am
FreeBSD /var/log/messages:
kernel: pid 1907 (vpnserver), jid 0, uid 0, was killed: failed to reclaim memory
Post by solo » Fri Apr 05, 2024 9:05 am
If you're using DE, try SE, or vice-versa https://github.com/SoftEtherVPN/SoftEth ... le-edition
If still memory issue, report it here https://github.com/SoftEtherVPN/SoftEtherVPN/issues
