Greetings to all! 😀 I recently started learning Ubuntu v20.04 on a remote VPS and the first thing I did was set up SoftEther VPN. Everything works, but there is one question left.
My rules in iptables are configured so that access to the server is possible only from one IP address - my home PC, other packets are dropped (iptables -P INPUT DROP). However, when I connect from my home PC via a smartphone, with a different IP address, the connection to SoftEther VPN is established 🐱👤I came to the conclusion that SoftEther somehow bypasses the iptables -P INPUT DROP policy. The secure NAT function is disabled.
Please explain how SoftEther bypasses iptables rules and what function is responsible for this?🧐
How does SoftEther bypass iptables policy?
Limon
Re: How does SoftEther bypass iptables policy?
Since SecureNAT's status is irrelevant to the issue at hand and SoftEther does not bypass iptables, it means your rules are incorrect. For Linux support go to https://ubuntuforums.org/.
shakibamoshiri
please share your iptables rules,
run this on your server
copy all the output and paste them here as code block
iptables-save-
Limon
Here you are:shakibamoshiri wrote: ↑Wed Apr 17, 2024 3:05 pmcopy all the output and paste them here as code block
# Generated by iptables-save v1.8.4 on Wed Apr 17 19:12:10 2024
*mangle
:PREROUTING ACCEPT [1296897:193942728]
:INPUT ACCEPT [1218334:155848549]
:FORWARD ACCEPT [32261:30806755]
:OUTPUT ACCEPT [1064496:112904514]
:POSTROUTING ACCEPT [1096950:143725871]
COMMIT
# Completed on Wed Apr 17 19:12:10 2024
*filter
:INPUT DROP [158028:12856103]
:FORWARD DROP [0:0]
:OUTPUT ACCEPT [1025004:108648745]
-A INPUT -i lo -j ACCEPT
-A INPUT -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
-A INPUT -s 192.168.10.0/24 -i tap_tap_virtual -m conntrack --ctstate NEW -j ACCEPT
-A INPUT -s 81.13.109.166/32 -m conntrack --ctstate NEW -j ACCEPT
-A FORWARD -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
-A FORWARD -i tap_tap_virtual -o eth0 -m conntrack --ctstate NEW -j ACCEPT
COMMIT
*nat
:PREROUTING ACCEPT [210697:20675008]
:INPUT ACCEPT [407:25131]
:OUTPUT ACCEPT [998708:69056389]
:POSTROUTING ACCEPT [998708:69056389]
-A POSTROUTING -s 192.168.10.0/24 -o eth0 -j MASQUERADE
COMMIT
# Completed on Wed Apr 17 19:12:10 2024-
shakibamoshiri
your rules seem correct to me
drop by default
just allow this source IP
no other IPs should be able to connect, please check SE server log at server_log/ directory to see from what IP the connection is made
drop by default
:INPUT DROP [158028:12856103]Code: Select all
-A INPUT -s 81.13.109.166/32 -m conntrack --ctstate NEW -j ACCEPT-
Limon
This time a warning window appeared when I switched to a mobile connection: This VPN Client is connected to the VPN Server 'name' by using the NAT Traversal (UDP Hole Punching) technology.shakibamoshiri wrote: ↑Thu Apr 18, 2024 7:58 amno other IPs should be able to connect, please check SE server log at server_log/ directory to see from what IP the connection is made
Accordingly, the IP address of the mobile device was recorded in the logs.
SoftEther VPN turned out to be a very cool development. The issue was successfully resolved, thank you for your participation! ;)
Using NAT-T on a remote VPS is completely superfluous and unheard of. Disable it along with DDNS in vpn_server.config.
declare DDnsClient
bool Disabled true
declare ServerConfiguration
bool DisableNatTraversal true
