Greetings everyone,
I faced a problem and hope someone can help me through. I noticed that even after successful connection I cannot visit filtered websites using VPN Gate Relay Server Package and started to investigate. My efforts was to no avail and so far I have only noticed the strange behavior of virtual network adapter which in its properties tab shows no received data and only a small amount of sent data.
Is this a problem or this is natural? Are there any special settings that I should tend to in order to tackle this problem or the root lies in another place?
I will be much grateful in case of receiving any hint.
Thanks everybody.
Data Send and Receive
Re: Data Send and Receive
If you are in a restricted corporate environment then it may take more than only a VPN to work around it.
Otherwise keep in mind... https://www.vpnusers.com/viewtopic.php? ... 36#p101240
