split-tunneling function
zack
any blocking split-tunneling function in saudi,riyadh country
zack
Re: split-tunneling function
iam using saudi regieon and its ubuntu server i configured vpn my client in windows but the static routing push table not working
its showing like "This feature is not supported. it has'nt been implemented yet on the open-source version of softether vpn
zack
thats means please clarify
SoftEther VPN is open source software, so you can modify its behavior to your liking.
Even if you are not good at programming, AI is your friend.
zack
this is the error
saifu.k
Did you solve the issue, I am also facing same issue
