OSPF over SSTP
RedCat
OSPF over SSTP
Hello everybody! I'm trying to configure OSPF between mikrotik routers via sstp tunnels, softether VPN is used as a server on the debian 11 operating system (softether secure nat is disabled), the problem is that it seems like ospf packets are sent between the routers, but on the routers themselves in the list of neighbors ospf is empty, but if I try to use mikrotik as a server, with the same interface settings, then neighbors appear, can the softether VPN server somehow influence this?
Re: OSPF over SSTP
FilterOSPF is ON? https://www.softether.org/4-docs/1-manu ... irtual_Hub
If not, try L2 instead of SSTP.
RedCat
Re: OSPF over SSTP
The OSPF filter is disabled, packets are reaching the router interface (checked with a packet sniffer), the question was whether the softether server could interfere with the contents of the packet?
