Is it possible to access VPN clients direct from server?
virtualitas
Post by virtualitas » Thu Apr 25, 2024 11:23 am
Dear all,
maybe a noob question - maybe I missed something during configuration.
But is it possible to access VPN clients direct from the VPN Server?
Thank you
Re: Is it possible to access VPN clients direct from server?
Post by solo » Thu Apr 25, 2024 12:05 pm
Yes, of course. Before you ask "how", it depends on your server's configuration - pity you didn't bother to describe it.
virtualitas
Post by virtualitas » Thu Apr 25, 2024 12:30 pm
it's just a VPN Dial in without any switches. The VPN Server is standalone on a small VPS and used to bypass a restrictive firewall.
Target is to provide some webservices via the VPS and set up a reverse proxy up there. I know, that it would be very performant, but it's just a school project.
I am using the in Softether included SecureNAT at the moment.
The config file:
# Software Configuration File
# You may edit this file when the VPN Server / Client / Bridge program is not running.
declare root
uint ConfigRevision 14
string Region US
declare DDnsClient
bool Disabled false
byte Key XXXXXXXXXXXXXX
string LocalHostname XXXXXXXXXXX
string ProxyHostName $
uint ProxyPort 0
uint ProxyType 0
string ProxyUsername $
declare IPsec
bool EtherIP_IPsec false
string IPsec_Secret vpn
string L2TP_DefaultHub DEFAULT
bool L2TP_IPsec false
bool L2TP_Raw false
declare ListenerList
declare Listener0
bool DisableDos false
bool Enabled true
uint Port 443
declare Listener1
bool Enabled true
uint Port 992
declare Listener2
bool Enabled true
uint Port 1194
declare Listener3
bool Enabled true
uint Port 5555
declare LocalBridgeList
bool DoNotDisableOffloading false
declare LocalBridge0
string DeviceName ens3
string HubName DEFAULT
bool LimitBroadcast false
bool MonitorMode false
bool NoPromiscuousMode false
bool TapMode false
declare ServerConfiguration
bool AcceptOnlyTls true
uint AutoSaveConfigSpan 300
string CipherName AES128-SHA
uint CurrentBuild 9799
bool DisableDosProction false
bool DisableIPsecAggressiveMode false
bool DisableJsonRpcWebApi false
bool DisableOpenVPNServer false
bool DisableSSTPServer false
bool DontBackupConfig false
bool EnableVpnAzure false
bool EnableVpnOverDns false
bool EnableVpnOverIcmp false
byte HashedPassword XXXXXXXXXXXXXXX
uint KeepConnectInterval 50
uint KeepConnectPort 80
uint KeepConnectProtocol 1
uint MaxConcurrentDnsClientThreads 512
uint MaxConnectionsPerIP 256
bool NoLinuxArpFilter false
bool NoSendSignature false
string OpenVPNDefaultClientOption dev-type$20tun,link-mtu$201500,tun-mtu$201500,cipher$20AES-128-CBC,auth$20SHA1,keysize$20128,key-method$202,tls-client
bool SaveDebugLog false
byte ServerCert XXXXXXXXXXXXXXX
byte ServerKey XXXXXXXXXXXXXXX
uint ServerLogSwitchType 4
uint ServerType 0
bool StrictSyslogDatetimeFormat false
bool Tls_Disable1_0 false
bool Tls_Disable1_1 false
bool Tls_Disable1_2 false
bool Tls_Disable1_3 false
bool UseKeepConnect true
bool UseWebTimePage false
bool UseWebUI false
declare GlobalParams
uint FIFO_BUDGET 10240000
uint MAX_BUFFERING_PACKET_SIZE 2560000
uint MAX_HUB_LINKS 1024
uint MAX_IP_TABLES 65536
uint MAX_MAC_TABLES 65536
uint MAX_SEND_SOCKET_QUEUE_SIZE 2560000
uint MAX_STORED_QUEUE_NUM 1024
uint MEM_FIFO_REALLOC_MEM_SIZE 655360
uint MIN_SEND_SOCKET_QUEUE_SIZE 320000
uint QUEUE_BUDGET 2048
uint SELECT_TIME 256
uint SELECT_TIME_FOR_NAT 30
uint STORM_CHECK_SPAN 500
declare ServerTraffic
declare RecvTraffic
uint64 BroadcastBytes 1003251561
uint64 BroadcastCount 4627121
uint64 UnicastBytes 323455617
uint64 UnicastCount 989544
declare SendTraffic
uint64 BroadcastBytes 1120842941
uint64 BroadcastCount 5169734
uint64 UnicastBytes 75815531
uint64 UnicastCount 132136
declare SyslogSettings
string HostName $
uint Port 0
uint SaveType 0
declare VirtualHUB
declare DEFAULT
uint64 CreatedTime 1714001124739
uint64 LastCommTime 1714014974272
uint64 LastLoginTime 1714012975543
uint NumLogin 3
bool Online true
string RadiusRealm $
uint RadiusRetryInterval 0
uint RadiusServerPort 1812
string RadiusSuffixFilter $
byte SecurePassword XXXXXXXXXXXXXXX
uint Type 0
declare AccessList
declare AdminOption
uint deny_bridge 0
uint deny_empty_password 0
uint deny_qos 0
uint deny_routing 0
uint max_accesslists 0
uint max_bitrates_download 0
uint max_bitrates_upload 0
uint max_groups 0
uint max_sessions 0
uint max_sessions_bridge 0
uint max_sessions_client 0
uint max_users 0
uint no_cascade 0
uint no_change_access_list 0
uint no_change_cert_list 0
uint no_change_crl_list 0
uint no_change_groups 0
uint no_change_log_config 0
uint no_change_msg 0
uint no_change_users 0
uint no_delete_iptable 0
uint no_delete_mactable 0
uint no_disconnect_session 0
uint no_enum_session 0
uint no_offline 0
uint no_online 0
uint no_query_session 0
uint no_read_log_file 0
uint no_securenat 0
uint no_securenat_enablenat 0
declare CascadeList
declare LogSetting
uint PacketLogSwitchType 4
uint PACKET_LOG_ARP 0
uint PACKET_LOG_DHCP 1
uint PACKET_LOG_ETHERNET 0
uint PACKET_LOG_ICMP 0
uint PACKET_LOG_IP 0
uint PACKET_LOG_TCP 0
uint PACKET_LOG_TCP_CONN 1
uint PACKET_LOG_UDP 0
bool SavePacketLog true
bool SaveSecurityLog true
uint SecurityLogSwitchType 4
declare Message
declare Option
uint AdjustTcpMssValue 0
bool DisableHttpParsing false
bool DisableIPParsing false
bool DisableIpRawModeSecureNAT false
bool FilterBPDU false
bool FilterIPv4 false
bool FilterIPv6 false
bool FilterNonIP false
bool FilterOSPF false
bool FilterPPPoE false
bool ManageOnlyPrivateIP true
uint MaxSession 0
bool NoArpPolling false
bool NoEnum false
bool NoIpTable false
bool NoIPv4PacketLog false
bool NoIPv6AddrPolling false
bool NoIPv6PacketLog false
bool NoLookBPDUBridgeId false
bool NoMacAddressLog true
bool NoManageVlanId false
uint RequiredClientId 0
string VlanTypeId 0x8100
declare SecureNAT
bool Disabled false
bool SaveLog true
declare VirtualDhcpServer
string DhcpDomainName $
bool DhcpEnabled true
uint DhcpExpireTimeSpan 7200
string DhcpLeaseIPEnd 192.168.30.200
string DhcpLeaseIPStart 192.168.30.10
string DhcpPushRoutes $
declare VirtualHost
string VirtualHostMacAddress 5E-11-2B-F2-D1-06
declare VirtualRouter
bool NatEnabled true
uint NatMtu 1500
uint NatTcpTimeout 1800
uint NatUdpTimeout 60
declare CertList
declare CrlList
declare GroupList
declare IPAccessControlList
declare UserList
declare XXXXXXXXXXXXXX
byte AuthNtLmSecureHash XXXXXXXXXXXXXXX
byte AuthPassword XXXXXXXXXXXXXXX
uint AuthType 1
uint64 CreatedTime 1714001391632
uint64 ExpireTime 0
string Note $
uint NumLogin 3
string RealName $
uint64 UpdatedTime 1714001391632
declare Traffic
declare RecvTraffic
uint64 BroadcastBytes 117564245
uint64 BroadcastCount 542453
uint64 UnicastBytes 64906813
uint64 UnicastCount 95237
declare SendTraffic
uint64 BroadcastBytes 39431
uint64 BroadcastCount 224
uint64 UnicastBytes 10705414
uint64 UnicastCount 32109
declare Traffic
declare RecvTraffic
declare SendTraffic
Post by solo » Thu Apr 25, 2024 1:40 pm
On the VPS install also SE client, set its vNIC to static 192.168.30.2 w/o default gateway and finally connect it to "localhost". Before you start pinging VPN clients on 192.168.30.x ensure their firewalls allow it.
