Force Chrome to NOT use VPN? SoftEther+VPNGate Client
Kiesman
Post by Kiesman » Thu Apr 25, 2024 11:31 pm
I tried doing some googling but I didn't find what I was looking for at all. Is there any way to Use SoftEther with VPNGate and have certain programs not use the VPN? Or alternatively make only one program use the VPN? I'm very new to VPNs
Kiesman
Re: Force Chrome to NOT use VPN? SoftEther+VPNGate Client
Post by Kiesman » Fri Apr 26, 2024 2:07 am
solo wrote:
Fri Apr 26, 2024 1:01 am
No, but depending on context, try this...
"How to make only a single program(game) go through VPN, but the rest ignore VPN and connect normally?"
This seemed promising until I got the error "Unacceptable Operation. Use the VPN Gate Utility to modify the connection setting for VPN Gate Public VPN Relay Servers." when trying to save after setting "No adjustments of routing table". And I can't find that option anywhere in the VPN Gate settings.
Post by solo » Fri Apr 26, 2024 2:37 am
This setting is available on regular SE client and manual address, eg:
host: public-vpn-222.opengw.net/tcp
port: 443
vhub: VPNGATE
user: vpn
pass: vpn
