Data use while idle
Beckler
Data use while idle
Simplest VPN configuration, 'ad-hoc' simply between 1 client program and 1 server. It works but data is transferring continuously - about 1MB/min, when connected but not being used. Both directions but I believe outgoing data from client is the larger one. Troubleshooting section mentions it and says make sure there are no level-2 loops; whatever that means!
Re: Data use while idle
Connect the VPN client and post amplification factor from your SoftEther server's LAN subnet.
