Issue on OpenWRT After Configuring Static Routes
taijutuka
Post by taijutuka » Wed May 01, 2024 11:41 am
I'm encountering an issue with the SoftEther VPN service running on my OpenWRT router. The problem arises whenever I configure static routes for the VPN connection; the VPN service fails to start correctly.
Additionally, I tried using the feature to push static routes to VPN clients. Unfortunately, it appears that this functionality has not been implemented in the version(Ver 4.38 Build 9760) of SoftEther I am currently using.
Could anyone provide guidance or suggestions on how to resolve the issue with the VPN service not starting after setting static routes? Also, I would appreciate any advice on alternative methods for pushing routes to clients.
Thank you in advance for your assistance!
Best regards
Re: Issue on OpenWRT After Configuring Static Routes
Post by solo » Wed May 01, 2024 1:12 pm
Hi, disable SecureNAT, enable local bridge and use dnsmasq to push routes.
