My setup
Host:
- Softether VPN (Local Bridge, SecureNAT)
- Web Server
- NGINX
Client:
- Windows 11
- Connected to Host using L2TP
Verify with https://whatismyipaddress.com/, and is able to see that my IP address is the Host's public IP address
But when I connect to my Web Server. NGINX reported my Client's Public IP address instead of the Host IP.
May I know what is wrong with my setup?
Softether is not hiding my public IP.
VSCPP
Re: Softether is not hiding my public IP.
You mean pick either Local Bridge or SecureNAT?
Actually the Local Bridge is not working. Even if I deleted it. The result is still the same.
autobottodoggo
What OS is the VPN host running?
OS is irrelevant. VPN host configuration is irrelevant too. The non-issue happens on VPN client where a direct route to SoftEther or any other VPN server must exist, hence "when I connect to my Web Server, NGINX reported my Client's Public IP address instead of the Host IP".
Is it clear now?
Is it clear now?
