Virtual Hub Client Message doesn't show
Wizard
Post by Wizard » Sat May 25, 2024 11:06 am
Just a minor... v4.33 build 9799 (Client and Server)
If you set a Client connect Message on a virtual Hub the message only shows when connecting using "normal" protocol (HTTPS port 443 in my case)...
It does not show if you "cripple" the available connections to DNS/ICMP only. This is true connecting DNS/ICMP to the VPN Server or, in case of a cluster, when only DNS/IMCP to any cluster-member (even when dedicated controller can be connected "normal" using HTTPS)...
Re: Virtual Hub Client Message doesn't show
Post by solo » Sat May 25, 2024 12:27 pm
Wizard
Post by Wizard » Wed Jul 10, 2024 6:08 pm
I can't. Link you sent to report the issue if for development-version v5.x, not v4.x...
Where should issues for that go ?
