Whenever I connect to SoftEther VPN (server running on cloud ), internet speed significantly drops to 2-4 MBPS.
However, without the VPN, much faster internet speed of 150-200 MBPS. Interestingly, when I connect to AWS VPN (Other VPN Server), the internet speed remains at a decent 50 MBPS, which is satisfactory.
I've diligently attempted various troubleshooting methods found online to resolve this issue, but unfortunately, none have proven successful thus far.
I treid below list of options with modifications
Maximum Number of TCP Connections
ENABLED/DISABLED SecureNAT
Maximum Number of TCP connections
Upload Bandwidth
Download Bandwidth
DisableKernalModeSecure
DisbaleRawModeSecure
suggest some solution or right approch to resolve this issue
Thanks!
Internet Speed is very slow, when connect to VPN
ramkunwar
ramkunwar
Re: Internet Speed is very slow, when connect to VPN
Item Name | Normal View|Simplified View
Time Span for Measurement | 00:00:15.008|
Data Correction for Ethernet Frames | Yes|
Communication Data Volume in Download Direction |1,481,281,517 Bytes| 1.48 GBytes
Communication Data Volume in Upload Direction | 582,305,878 Bytes| 582.31 MBytes
Total Communication Data Volume |2,063,587,395 Bytes| 2.06 GBytes
Relay Device Input Output Total Throughput Computation| No|
Average Throughput in Download Direction | 789,595,691 bps| 789.60 Mbps
Average Throughput in Upload Direction | 310,397,589 bps| 310.40 Mbps
Total Average Throughput | 1,099,993,280 bps| 1.10 Gbps-
ramkunwar
VPN Server>ServerInfoGet
ServerInfoGet command - Get server information
Item |Value
Product Name |SoftEther VPN Server (64 bit)
Version |Version 4.42 Build 9798 (English)
Build |Compiled 2023/06/30 11:06:58 by buildsan at crosswin with OpenSSL 3.0.9
Host Name |VPN-SERVR-CPX11-US-EAST
Server Type |Standalone Server
Type of Operating System |Linux
Product Name of Operating System|Linux
Operating System Vendor |Unknown Vendor
Operating System Version |Unknown Linux Version
Type of OS Kernel |Linux Kernel
Version of OS Kernel |Linux Kernel-
ramkunwar
VPN Server>BridgeList
BridgeList command - Get List of Local Bridge Connection
Number|Virtual Hub Name|Network Adapter or Tap Device Name|Status
1 |DEFAULT |eth0 |Operating
The command completed successfully.-
OK, more info is trickling in, yet you still have not posted what was asked for. Before you do, try another config to resolve this issue - do not bridge eth0 directly but create a SE soft tap and then bridge it to eth0.
LeeHS
Maybe turning on "Disable UDP Acceleration" and "Disable NAT-T" can increase the speed. This feature is in the VPN properties and advanced settings of SoftEther VPN Client.
slitherince
I recommend changing the VPN protocol to UDP and adjusting the MTU settings to around 1400 bytes.
