Help setting up Softether VPN on Windows 10
Rafael Segovia
Post by Rafael Segovia » Mon May 27, 2024 7:35 pm
I have clue how or where to find the info to set up Softether VPN.
All I want is to see the VPN list with countries to connect to them locally.
I have watched many tutorials but I just can't figure it out.
What information do I have to put on each field? and where do I find that info on Windows 10?
Attached you can find what I see.
Thanks.
Rafael Segovia
Re: Help setting up Softether VPN on Windows 10
Post by Rafael Segovia » Tue May 28, 2024 9:02 am
Right I have seen that already.
The problem is I don't see the VPN gate server option.
Please look at my screenshots provided in the post.
Thanks.
Post by solo » Tue May 28, 2024 11:19 am
In your screenshot I see "Developer Edition". It is not supported officially. Uninstall it and follow the given instructions precisely.
Rafael Segovia
Post by Rafael Segovia » Tue May 28, 2024 3:00 pm
Fantastic!
that was it. For some reason I downloaded a developer version which did not have the VPN gate server option.
I reinstalled the regular version and now I can see it.
I really appreciate your help!
Thanks.
