Requirements
There are 8 LAN servers in the cloud server cluster CA and 4 LAN servers in the cloud server cluster CB; deploy SE in server A in CA and deploy SE in server B in CB, connect the SE of servers A and B through cascade connection, and after the window client is connected through VPN, it can access all servers in the cloud server cluster CA and cloud server cluster CB through the intranet IP, and can access the external network. The displayed IP is the window client IP.
Current status:
Server A
Server
Version: CentOS Linux release 7.9.2009 (Core)
[root@ao mht-softether]# cat /proc/version
Linux version 4.19.0-9.el7.ucloud.x86_64 (root@2549ed846496) (gcc version 4.8.5 20150623 (Red Hat 4.8.5-16) (GCC)) #1 SMP Mon Sep 28 10:29:09 UTC 2020
[root@ao mht-softether]# more /etc/centos-release
External network: AAA.AAA.AAA.AAA
Internal network: 10.9.94.119
Docker Container
Server: alpine 3.16.7
/usr/vpnserver # cat /proc/version
/usr/vpnserver # more /etc/alpine-release
3.16.7
eth0: 172.20.90.2
tap_soft:192.168.31.1
/usr/vpnserver # ifconfig
eth0 Link encap:Ethernet HWaddr 02:42:AC:14:5A:02
inet addr:172.20.90.2 Bcast:172.20.90.255 Mask:255.255.255.0
RX packets:122162 errors:0 dropped:0 overruns:0 frame:0
TX packets:118276 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:31195291 (29.7 MiB) TX bytes:18085125 (17.2 MiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:73455 errors:0 dropped:0 overruns:0 frame:0
TX packets:73455 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:13364945 (12.7 MiB) TX bytes:13364945 (12.7 MiB)
tap_soft Link encap:Ethernet HWaddr 5E:AD:A2:57:89:B5
inet addr:192.168.31.1 Bcast:192.168.31.255 Mask:255.255.255.0
RX packets:1167 errors:0 dropped:0 overruns:0 frame:0
TX packets:18 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:269744 (263.4 KiB) TX bytes:4210 (4.1 KiB)
/usr/vpnserver # ip route show
default via 172.20.90.1 dev eth0
172.20.90.0/24 dev eth0 scope link src 172.20.90.2
192.168.31.0/24 dev tap_soft scope link src 192.168.31.1
/usr/vpnserver # route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 172.20.90.1 0.0.0.0 UG 0 0 0 eth0
172.20.90.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
192.168.31.0 0.0.0.0 255.255.255.0 U 0 0 0 tap_soft
dnsmasq
/usr/vpnserver # more /etc/dnsmasq.conf
local-service
port=0
bind-interfaces
interface=tap_soft
dhcp-authoritative
dhcp-no-override
dhcp-range=tap_soft,192.168.31.10,192.168.31.49,12h
dhcp-option=tap_soft,3
dhcp-option=tap_soft,121,192.168.0.0/24,192.168.33.1,10.9.94.0/24,192.168.31.1,10.10.12.0/24,192.168.31.1
dhcp-option=tap_soft,249,192.168.0.0/24,192.168.33.1,10.9.94.0/24,192.168.31.1,10.10.12.0/24,192.168.31.1
conf-dir=/etc/dnsmasq.d/,*.conf
iptables
iptables -t nat -A POSTROUTING -s 192.168.31.0/24 -j SNAT --to-source 172.20.90.2
iptables -t nat -L -n -v --line-numbers
/usr/vpnserver # iptables -t nat -L -n -v --line-numbers
Chain PREROUTING (policy ACCEPT 578 packets, 141K bytes)
num pkts bytes target prot opt in out source destination
Chain INPUT (policy ACCEPT 24 packets, 5370 bytes)
Chain OUTPUT (policy ACCEPT 58268 packets, 4022K bytes)
1 26424 1824K DOCKER_OUTPUT all -- * * 0.0.0.0/0 127.0.0.11
Chain POSTROUTING (policy ACCEPT 77679 packets, 5361K bytes)
1 5 1314 SNAT all -- * * 192.168.31.0/24 0.0.0.0/0 to:172.20.90.2
Chain DOCKER_OUTPUT (1 references)
1 0 0 DNAT tcp -- * * 0.0.0.0/0 127.0.0.11 tcp dpt:53 DNAT [unsupported revision]
2 26424 1824K DNAT udp -- * * 0.0.0.0/0 127.0.0.11 udp dpt:53 DNAT [unsupported revision]
Chain DOCKER_POSTROUTING (0 references)
1 0 0 SNAT tcp -- * * 127.0.0.11 0.0.0.0/0 tcp spt:33581 to::53
2 0 0 SNAT udp -- * * 127.0.0.11 0.0.0.0/0 udp spt:43082 to::53
Server B
Server
[root@iZbp1a8vtwsdkuj7v7o2mfZ mht-softether]# cat /proc/version
Linux version 3.10.0-1160.114.2.el7.x86_64 (mockbuild@kbuilder.bsys.centos.org) (gcc version 4.8.5 20150623 (Red Hat 4.8.5-44) (GCC) ) #1 SMP Wed Mar 20 15:54:52 UTC 2024
[root@iZbp1a8vtwsdkuj7v7o2mfZ mht-softether]# more /etc/centos-release
External network: BBB.BBB.BBB.BBB
Internal network: 192.168.0.36
Docker Container
3.16.7
eth0: 172.20.41.2
tap_soft:192.168.33.1
eth0 Link encap:Ethernet HWaddr 02:42:AC:14:29:02
inet addr:172.20.41.2 Bcast:172.20.41.255 Mask:255.255.255.0
RX packets:70887 errors:0 dropped:0 overruns:0 frame:0
TX packets:76048 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:31445471 (29.9 MiB) TX bytes:21146620 (20.1 MiB)
RX packets:93026 errors:0 dropped:0 overruns:0 frame:0
TX packets:93026 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:10269030 (9.7 MiB) TX bytes:10269030 (9.7 MiB)
tap_soft Link encap:Ethernet HWaddr 5E:B2:3E:75:BD:52
inet addr:192.168.33.1 Bcast:192.168.33.255 Mask:255.255.255.0
inet6 addr: fe80::5cb2:3eff:fe75:bd52/64 Scope:Link
RX packets:4986 errors:0 dropped:0 overruns:0 frame:0
TX packets:14710 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:902357 (881.2 KiB) TX bytes:12243453 (11.6 MiB)
default via 172.20.41.1 dev eth0
172.20.41.0/24 dev eth0 scope link src 172.20.41.2
192.168.33.0/24 dev tap_soft scope link src 192.168.33.1
0.0.0.0 172.20.41.1 0.0.0.0 UG 0 0 0 eth0
172.20.41.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
192.168.33.0 0.0.0.0 255.255.255.0 U 0 0 0 tap_soft
dnsmasq
local-service
port=0
bind-interfaces
interface=tap_soft
dhcp-authoritative
dhcp-no-override
dhcp-range=tap_soft,192.168.33.50,192.168.33.90,12h
iptables
iptables -t nat -A POSTROUTING -s 192.168.33.0/24 -j SNAT --to-source 172.20.41.2
Chain PREROUTING (policy ACCEPT 685 packets, 148K bytes)
Chain INPUT (policy ACCEPT 43 packets, 3806 bytes)
Chain OUTPUT (policy ACCEPT 35084 packets, 2422K bytes)
1 42910 2962K DOCKER_OUTPUT all -- * * 0.0.0.0/0 127.0.0.11
Chain POSTROUTING (policy ACCEPT 70142 packets, 4841K bytes)
1 21 1784 SNAT all -- * * 192.168.33.0/24 0.0.0.0/0 to:172.20.41.2
1 0 0 DNAT tcp -- * * 0.0.0.0/0 127.0.0.11 tcp dpt:53 to:127.0.0.11:41921
2 42910 2962K DNAT udp -- * * 0.0.0.0/0 127.0.0.11 udp dpt:53 to:127.0.0.11:52169
1 0 0 SNAT tcp -- * * 127.0.0.11 0.0.0.0/0 tcp spt:41921 to::53
2 0 0 SNAT udp -- * * 127.0.0.11 0.0.0.0/0 udp spt:52169 to::53
Cascade
A is the client connection entrance. Set up cascade B's SE in A's SE. Cluster CC, cluster CD, etc. may be added in series to connect to B's SE, such as A->B->C->D...
Client: window SoftEther VPN Client
Problem description:
Case 1: If using SecureNAT's vNAT and vDHCP, the requirements can be met, but the access speed is too slow;
Case 2: Using softether+dnsmasq+iptables, the client can access the CA intranet by connecting to A's SE, and the client can access the CB intranet by connecting to B's SE;
Case 3: Using softether+dnsmasq+iptables+cascade (site-to-site), the client connects to A's SE, sometimes responding to A's network segment (192.168.31.XXX), sometimes responding to B's network segment (192.168.33.XXX), when responding to A's network segment, it can only access the CA intranet, and when responding to B's network segment, it can only access the CB intranet. What is needed is that it should respond to A's network segment, and can access all intranets of CA and CB at the same time.
Please help me.
Docker softether local bridge cascade(site to site)
775118134
Re: Docker softether local bridge cascade(site to site)
With two DHCP servers on L2 network, no wonder you get random IP assignments.
775118134
Thank you for your reply.With two DHCP servers on L2 network, no wonder you get random IP assignments.
I am not familiar with the network. How should I modify it?
Should I close dnsmasq in server B and delete iptables and point dhcp-option=tap_soft,249 and dhcp-option=tap_soft,121 of dnsmasq in server A to 192.168.31.1 of server A? 192.168.0.0/24,192.168.31.1,10.9.94.0/24,192.168.31.1,10.10.12.0/24,192.168.31.1
According to the above modification, the IP segments obtained are all set in server A and are normal. The cascade connection server B in server A is also online (established). The client can only ping the LAN in server cluster CA, but not the LAN in server cluster CB.
Close dnsmasq B, don't delete iptables, and correct the routes.
775118134
775118134
Can an expert help me take a look?
