routing trough strongswan connection
rakaris
Post by rakaris » Tue Jun 04, 2024 3:30 pm
Hello!
I'm new with this powerfull product and I need some advice. I have installed SoftEther VPN server with SecureNAT and dedicated IP for SoftEther, I'm able to connect to it and use like vpn gateway. The server has configured a Strongswan ipsec connection to some resource. I want to accomplish that SoftEther VPN clients can connect to Strongswan ipsec tunnel. Is it possible to accomplish and nd if yes how to do it?
Could you help me please?
Thanks in advance!
Re: routing trough strongswan connection
Post by solo » Tue Jun 04, 2024 10:37 pm
rakaris
Post by rakaris » Wed Jun 05, 2024 12:22 pm
thank you for the links.
I have done some configuration based on link you posted and published it on the link below
https://www.vpnusers.com/viewtopic.php? ... 65#p101765
If someone have experience / understanding of the problem please check the link above.
