Why is the Softether VPN Client process/service using so much bandwidth when not connected to anything?
goonlord
This isn't the first time happening to me. The Softether VPN Client service would eat more than 25 Mbps of network bandwidth when not connected to anything and I had to disable the service altogether to stop it, as ending the process will simply prompt the service to restart it. Not sure what's happening here but it honestly feels like a malware to me. It actually slowed down my Internet significantly and increased my ping in games. I have done a virus scan via Windows Defender and Malwarebytes and found nothing. What I did before is just uninstalling it and it would be gone until I needed to use the VPN again. Thought they fixed it after 7 months but I guess not.
I'm on Windows 10, connected to ethernet if that matters.
Re: Why is the Softether VPN Client process/service using so much bandwidth when not connected to anything?
Softether is open source, anyone can compile it with malware and call this construct "Softether", so where did you get it and what version? (Post your sigcheck here)
goonlord
Ok turns out I was using the February (2024.02.25) build, gonna update it and see how it goes. Also I always get my installation here https://www.vpngate.net/en/download.aspx which I suppose is the official site (that includes the plugin)?solo wrote: ↑Thu Jun 13, 2024 3:40 pmSoftether is open source, anyone can compile it with malware and call this construct "Softether", so where did you get it and what version? (Post your sigcheck here)
goonlord
Alright so I updated and the process dropped the network usage to 0.1Mbps-0.8Mbps which is much better. But it would be ideal for it to not use any network bandwidth when not connected anything though. Here's the sigcheck for your reference. I don't know if I'm doing it right though.solo wrote: ↑Thu Jun 13, 2024 3:40 pmSoftether is open source, anyone can compile it with malware and call this construct "Softether", so where did you get it and what version? (Post your sigcheck here)
Sigcheck v2.90 - File version and signature viewer
Copyright (C) 2004-2022 Mark Russinovich
Sysinternals - www.sysinternals.com
c:\program files\softether vpn client\installer.cache:
Verified: Signed
Signing date: 10:55 AM 31/08/2023
Publisher: SOFTETHER CORPORATION
Company: SoftEther VPN Project at University of Tsukuba, Japan.
Description: SoftEther VPN
Product: SoftEther VPN
Prod version: 4, 43, 0, 9799
File version: 4, 43, 0, 9799
MachineType: 32-bit
c:\program files\softether vpn client\vpnclient.exe:
Verified: Signed
Signing date: 10:53 AM 31/08/2023
Publisher: SoftEther Corporation
MachineType: 32-bit
c:\program files\softether vpn client\vpnclient_x64.exe:
Verified: Signed
MachineType: 64-bit
c:\program files\softether vpn client\vpncmd.exe:
Verified: Signed
MachineType: 32-bit
c:\program files\softether vpn client\vpncmd_x64.exe:
Verified: Signed
Signing date: 10:52 AM 31/08/2023
MachineType: 64-bit
c:\program files\softether vpn client\vpncmgr.exe:
Verified: Signed
MachineType: 32-bit
c:\program files\softether vpn client\vpncmgr_x64.exe:
Verified: Signed
MachineType: 64-bit
c:\program files\softether vpn client\VpnGatePlugin_x64.dll:
Verified: Unsigned
Link date: 10:52 AM 31/08/2023
Publisher: n/a
Company: University of Tsukuba
Description: VPN Gate Plug-in DLL for SoftEther VPN
Product: VPN Gate Software
MachineType: 64-bit
c:\program files\softether vpn client\VpnGatePlugin_x86.dll:
Verified: Unsigned
Link date: 10:51 AM 31/08/2023
Publisher: n/a
MachineType: 32-bit
c:\program files\softether vpn client\vpninstall.exe:
Verified: Signed
MachineType: 32-bit
c:\program files\softether vpn client\vpnsetup.exe:
Verified: Signed
MachineType: 32-bit
c:\program files\softether vpn client\vpnsetup_x64.exe:
Verified: Signed
MachineType: 64-bit
On the same vpngate-client-2024.06.15-build-9799.159115 there is no traffic whatsoever after a brief connection to random VPN Gate and then idling for 1 hour as logged below...
goonlord
I will try to use the network monitor app you used and see how it goes. I'm only basing it off task manager for now.
goonlord
Alright logs shows that it's uploading something (10 MB after 40 mins) while downloading a little bit of stuff (0.66 MB). Used netstat -ban and found these IP that vpngate is connected to. Also ran it again with the -o parameter and found the unnamed SoftEther Service (PID 516) is connected to what seems to be an Indian IP address? Anyway here's the log:
Please run these commands:
If or when the unwelcome traffic re-appears, run and post as code:
Also include in your post relevant log from "C:\Program Files\SoftEther VPN Client\client_log" folder at the time of the rogue connection.
While at it, open up "SoftEther VPN Client Manager" and check the GUI for any active connection.
"C:\Program Files\SoftEther VPN Client\vpncmd.exe" localhost /client /cmd RemoteDisable
net stop SEVPNCLIENT
net start SEVPNCLIENTCode: Select all
ipconfig /all
netstat -r
goonlord
I did another run of Malwarebytes, Windows Defender full scan + offline scan just in case and again, found nothing. Windows 10 is on the latest version as well. Also the issue seems to have worsened as it's starting to go at 300Kbps~ sometimes now, even after running your commands. Here's the ipconfig/netstat log:solo wrote: ↑Sat Jun 15, 2024 6:52 pmPlease run these commands:
If or when the unwelcome traffic re-appears, run and post as code:Code: Select all
"C:\Program Files\SoftEther VPN Client\vpncmd.exe" localhost /client /cmd RemoteDisable net stop SEVPNCLIENT net start SEVPNCLIENTAlso include in your post relevant log from "C:\Program Files\SoftEther VPN Client\client_log" folder at the time of the rogue connection.Code: Select all
ipconfig /all netstat -r
C:\WINDOWS\system32>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : SPECTAL
Primary Dns Suffix . . . . . . . :
Unknown adapter VPN - VPN Client:
Description . . . . . . . . . . . : VPN Client Adapter - VPN
Physical Address. . . . . . . . . : 5E-27-01-F5-93-7E
Ethernet adapter Ethernet 5:
Description . . . . . . . . . . . : Realtek PCIe GbE Family Controller #2
Physical Address. . . . . . . . . : 00-D8-61-D4-01-8B
Link-local IPv6 Address . . . . . : fe80::7f72:51a0:6472:c045%3(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.195(Preferred)
Lease Obtained. . . . . . . . . . : Sunday, 16 June 2024 11:59:46 PM
Lease Expires . . . . . . . . . . : Sunday, 23 June 2024 11:59:46 PM
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DHCPv6 IAID . . . . . . . . . . . : 536926305
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-25-E5-47-06-00-D8-61-D4-01-8B
DNS Servers . . . . . . . . . . . : 2001:4860:4860::8888
2001:4860:4860::8844
8.8.8.8
8.8.4.4
C:\WINDOWS\system32>netstat -r
Interface List
12...5e 27 01 f5 93 7e ......VPN Client Adapter - VPN
3...00 d8 61 d4 01 8b ......Realtek PCIe GbE Family Controller #2
IPv4 Route Table
Active Routes:
0.0.0.0 0.0.0.0 192.168.0.1 192.168.0.195 25
127.0.0.0 255.0.0.0 On-link 127.0.0.1 331
127.0.0.1 255.255.255.255 On-link 127.0.0.1 331
127.255.255.255 255.255.255.255 On-link 127.0.0.1 331
192.168.0.0 255.255.255.0 On-link 192.168.0.195 281
192.168.0.195 255.255.255.255 On-link 192.168.0.195 281
192.168.0.255 255.255.255.255 On-link 192.168.0.195 281
224.0.0.0 240.0.0.0 On-link 127.0.0.1 331
224.0.0.0 240.0.0.0 On-link 192.168.0.195 281
255.255.255.255 255.255.255.255 On-link 127.0.0.1 331
255.255.255.255 255.255.255.255 On-link 192.168.0.195 281
Persistent Routes:
None
IPv6 Route Table
Active Routes:
If Metric Network Destination Gateway
1 331 ::1/128 On-link
3 281 fe80::/64 On-link
3 281 fe80::7f72:51a0:6472:c045/128
On-link
1 331 ff00::/8 On-link
3 281 ff00::/8 On-link
Persistent Routes:
None
goonlord
Honestly I'm gonna assume that it's either there's something wrong with the client, or there's rogue VPN servers in the list. It would be weird for a malware (which I have yet to detect any) to be targeting SoftEther services exclusively and be permanently gone if I uninstall the client, especially when I downloaded the client from the official source. The logs you requested (and probably this reply) is still pending mod approval, but I'm giving my 2 cents anyway.
I have used Proton VPN, connected to both Japan and US servers for a bit and still yet to meet any issues like this. Not that I'm saying SoftEther is bad, I'm just pointing this out. I've been using SE for years few years ago for gaming and this issue never happened to me before.
Can you run AppNetworkCounter for 1 hour "when not connected to anything" and post its screenshot? It is essential to select fully visible "application path" and sent/received bytes like this:
goonlord
There you go. The issue got way worse and uploaded 4GB worth of data lol. Also vpncmgr didn't show up so I assumed it did not consumed any bandwidth which I suppose is normal?solo wrote: ↑Sun Jun 16, 2024 4:11 pmCan you run AppNetworkCounter for 1 hour "when not connected to anything" and post its screenshot? It is essential to select fully visible "application path" and sent/received bytes like this:
Malware can be detected only if its signature is known. In your case some malware injects itself into the vpnclient_x64 process in order to pass through your firewall, it is as simple as that, and has nothing to do with SoftEther's devs evil ideas. It works flawlessly for me and thousands of other users. You could verify it yourself on a fresh and clean Windows installation in a virtual machine or another PC. As for your current "Windows 10" predicament, it may range from a hardcore rootkit infection to a mild exploit, and any countermeasures may be ineffective or short-lived. That said, if you wish, we could probably inconclusively check out a few exploit vectors - get PC Hunter and when the rogue traffic keeps flowing run it and click "Examination", select "hide safe items" and click "Generate...", wait 10 minutes, click "Terminate...", click "Export..." and post the file as code.
goonlord
If the software is actually fine then there's probably rogue VPN servers among the list. Because it still doesn't make sense to me that a malware would specifically target just SoftEther and not something more "popular". I have not downloaded anything suspicious or visited any weird sites AFAIK.solo wrote: ↑Mon Jun 17, 2024 6:30 pmMalware can be detected only if its signature is known. In your case some malware injects itself into the vpnclient_x64 process in order to pass through your firewall, it is as simple as that, and has nothing to do with SoftEther's devs evil ideas. It works flawlessly for me and thousands of other users. You could verify it yourself on a fresh and clean Windows installation in a virtual machine or another PC. As for your current "Windows 10" predicament, it may range from a hardcore rootkit infection to a mild exploit, and any countermeasures may be ineffective or short-lived. That said, if you wish, we could probably inconclusively check out a few exploit vectors - get PC Hunter and when the rogue traffic keeps flowing run it and click "Examination", select "hide safe items" and click "Generate...", wait 10 minutes, click "Terminate...", click "Export..." and post the file as code.
As for the PC Hunter thing, it showed a "Load driver error" but I ignored it (Google said it doesn't support newer version of Windows) and proceed to do the Examination thing you asked. Here's the log:
PC Hunter Standard --- Computer Examination Report
Examination Date: 2024-06-18 18:20
OS Information: Microsoft Windows 10 (build 19045), 64-bit
Internet Explorer: 9.11.19041.0
Examination Items:
Process
Process Modules
Process Threads
Kernel Module
Notify Routine
Filter
DPC Timer
Worker Thread
HalDispatchTable
HalPrivateDispatchTable
HalAcpiDispatchTable
MiniFilter
File System
Sfilter FileSystem Filter Callback
ClassInitData Callback
Npfs Dispatch Fun
Msfs Dispatch Fun
Usbport Dispatch Fun
System Debug
Object Hijack
Direct IO
GDT
SSDT
Shadow SSDT
FSD
Keyboard
I8042prt
Mouclass
Partmgr
Classpnp
Atapi
Acpi
Scsi
Kernel Hook
PTE HOOK
Object Type
IDT
Message Hook
Process Hook
KernelCallbackTable
Port
Tcpip
Ndis Handler
IE Plugin
IE Shell
Spi
Hosts File
Startup
Service
Schedule Task
File Association
IFEO
IME/CTF
Firewall Rule
System User Name
Scan MBR Rootkit
Process
Process Modules
Process Threads
Kernel Module
Notify Routine
Nothing
Filter
DPC Timer
Worker Thread
HalDispatchTable
Nothing
Nothing
Nothing
MiniFilter
Nothing
File System
Nothing
Nothing
Nothing
Npfs Dispatch Fun
Nothing
Msfs Dispatch Fun
Nothing
Nothing
System Debug
Nothing
Object Hijack
Nothing
Direct IO
GDT
Nothing
SSDT
Nothing
Shadow SSDT
Nothing
FSD
Nothing
Keyboard
Nothing
I8042prt
Nothing
Mouclass
Nothing
Partmgr
Nothing
Classpnp
Nothing
Atapi
Nothing
Acpi
Nothing
Scsi
Nothing
Kernel Hook
Nothing
PTE HOOK
Nothing
Object Type
Nothing
IDT
Nothing
Message Hook
Nothing
Process Hook
Nothing
KernelCallbackTable
Nothing
Port
Nothing
Tcpip
Nothing
Ndis Handler
Nothing
IE Plugin
Nothing
IE Shell
Nothing
Spi
Nothing
Hosts File
Nothing
Startup
Nothing
Service
AdobeARMservice *---* Stopped *---* Disabled *---* "C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe" *---* Adobe Inc. *---* *---*
AGMService *---* Stopped *---* Disabled *---* "C:\Program Files (x86)\Common Files\Adobe\AdobeGCClient\AGMService.exe" *---* Adobe Systems, Incorporated *---* *---*
AGSService *---* Stopped *---* Disabled *---* "C:\Program Files (x86)\Common Files\Adobe\AdobeGCClient\AGSService.exe" *---* Adobe Systems, Incorporated *---* *---*
AntiCheatExpert Service *---* Stopped *---* Manual *---* "C:\Program Files\AntiCheatExpert\SGuard\x64\SGuardSvc64.exe" -autorun *---* ANTICHEATEXPERT.COM *---* *---*
BEService *---* Stopped *---* Manual *---* "C:\Program Files (x86)\Common Files\BattlEye\BEService.exe" *---* File not found *---* *---*
EasyAntiCheat *---* Stopped *---* Manual *---* "C:\Program Files (x86)\EasyAntiCheat\EasyAntiCheat.exe" *---* Epic Games, Inc *---* *---*
EasyAntiCheat_EOS *---* Stopped *---* Manual *---* "C:\Program Files (x86)\EasyAntiCheat_EOS\EasyAntiCheat_EOS.exe" *---* Epic Games, Inc. *---* *---*
FvSvc *---* Stopped *---* Manual *---* "C:\Program Files\NVIDIA Corporation\FrameViewSDK\nvfvsdksvc_x64.exe" -service *---* NVIDIA *---* *---*
GoogleChromeElevationService *---* Stopped *---* Disabled *---* "C:\Program Files (x86)\Google\Chrome\Application\96.0.4664.45\elevation_service.exe" *---* Google LLC *---* *---*
GoogleIMEJaCacheService *---* Started *---* Automatic *---* "C:\Program Files (x86)\Google\Google Japanese Input\GoogleIMEJaCacheService.exe" *---* Google Inc. *---* *---*
gupdate *---* Stopped *---* Disabled *---* "C:\Program Files (x86)\Google\Update\GoogleUpdate.exe" /svc *---* Google Inc. *---* *---*
gupdatem *---* Stopped *---* Disabled *---* "C:\Program Files (x86)\Google\Update\GoogleUpdate.exe" /medsvc *---* Google Inc. *---* *---*
MozillaMaintenance *---* Stopped *---* Disabled *---* "C:\Program Files (x86)\Mozilla Maintenance Service\maintenanceservice.exe" *---* Mozilla Foundation *---* *---*
nlsvc *---* Stopped *---* Disabled *---* "C:\Program Files\Locktime Software\NetLimiter 4\NLSvc.exe" *---* Locktime Software *---* *---*
npggsvc *---* Stopped *---* Manual *---* C:\WINDOWS\syswow64\GameMon.des -service *---* INCA Internet Co., Ltd. *---* *---*
NvContainerLocalSystem *---* Started *---* Automatic *---* "C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe" -s NvContainerLocalSystem -a -f "C:\ProgramData\NVIDIA Corporation\NVIDIA app\NvContainer\NvContainerLocalSystem.log" -l 3 -d "C:\Program Files\NVIDIA Corporation\NvContainer\plugins\LocalSystem" -r -p 30000 -ert *---* NVIDIA Corporation *---* *---*
NVDisplay.ContainerLocalSystem *---* Started *---* Automatic *---* C:\WINDOWS\syswow64\DriverStore\FileRepository\nvmdig.inf_amd64_23954e33c8a39da4\Display.NvContainer\NVDisplay.Container.exe -s NVDisplay.ContainerLocalSystem -f C:\ProgramData\NVIDIA\NVDisplay.ContainerLocalSystem.log -l 3 -d C:\WINDOWS\System32\DriverStore\FileRepository\nvmdig.inf_amd64_23954e33c8a39da4\Display.NvContainer\plugins\LocalSystem -r -p 30000 -cfg NVDisplay.ContainerLocalSystem\LocalSystem /ert *---* File not found *---* *---*
ProtonVPN Service *---* Stopped *---* Manual *---* "C:\Program Files\Proton\VPN\v3.2.11\ProtonVPNService.exe" *---* ProtonVPN *---* *---*
ProtonVPN WireGuard *---* Stopped *---* Manual *---* "C:\Program Files\Proton\VPN\v3.2.11\ProtonVPN.WireGuardService.exe" "C:\Program Files\Proton\VPN\v3.2.11\ServiceData\WireGuard\ProtonVPN.conf" *---* ProtonVPN *---* *---*
RunSwUSB *---* Started *---* Automatic *---* C:\Windows\runSW.exe *---* *---* *---*
SEVPNCLIENT *---* Started *---* Automatic *---* "C:\Program Files\SoftEther VPN Client\vpnclient_x64.exe" /service *---* SoftEther VPN Project at University of Tsukuba, Japan. *---* *---*
ssh-agent *---* Stopped *---* Disabled *---* C:\Windows\System32\OpenSSH\ssh-agent.exe *---* File not found *---* *---*
ss_conn_launcher_service *---* Stopped *---* Manual *---* C:\Windows\System32\Samsung\EasySetup\ss_conn_launcher.exe *---* Samsung Electronics Co., Ltd. *---* *---*
ss_conn_service *---* Stopped *---* Manual *---* "C:\Program Files\Samsung\USB Drivers\27_ssconn\conn\ss_conn_service.exe" *---* DEVGURU Co., LTD. *---* *---*
ss_conn_service2 *---* Stopped *---* Manual *---* "C:\Program Files\Samsung\USB Drivers\28_ssconn2\conn\ss_conn_service2.exe" *---* DEVGURU Co., LTD. *---* *---*
Steam Client Service *---* Stopped *---* Manual *---* "C:\Program Files (x86)\Common Files\Steam\steamservice.exe" /RunAsService *---* Valve Corporation *---* *---*
ucldr_PSO2_JP *---* Stopped *---* Manual *---* "C:\Program Files\Common Files\Wellbia.com\ucldr_PSO2_JP.exe" *---* Wellbia.com Co., Ltd. *---* *---*
vgc *---* Stopped *---* Manual *---* "C:\Program Files\Riot Vanguard\vgc.exe" *---* Riot Games, Inc. *---* *---*
Schedule Task
BackgroundDownload *---* \Microsoft\VisualStudio\Updates\BackgroundDownload *---* C:\Program Files (x86)\Microsoft Visual Studio\Installer\resources\app\ServiceHub\Services\Microsoft.VisualStudio.Setup.Service\BackgroundDownload.exe *---* *---* Disable *---* Microsoft
FODCleanupTask *---* \Microsoft\Windows\HelloFace\FODCleanupTask *---* C:\Windows\System32\WinBioPlugIns\FaceFodUninstaller.exe *---* *---* Enable *---* File not found
GatherNetworkInfo *---* \Microsoft\Windows\NetTrace\GatherNetworkInfo *---* C:\Windows\System32\gatherNetworkInfo.vbs *---* Network information collector *---* Enable *---* File not found
Firefox Default Browser Agent 308046B0AF4A39CB *---* \Mozilla\Firefox Default Browser Agent 308046B0AF4A39CB *---* C:\Program Files\Mozilla Firefox\default-browser-agent.exe *---* The Default Browser Agent task checks when the default changes from Firefox to another browser. If the change happens under suspicious circumstances, it will prompt users to change back to Firefox no more than two times. This task is installed automatically by Firefox, and is reinstalled when Firefox updates. To disable this task, update the “default-browser-agent.enabled” preference on the about:config page or the Firefox enterprise policy setting “DisableDefaultBrowserAgent”. *---* Enable *---* Mozilla Foundation
BlueStacksHelper_nxt *---* \BlueStacksHelper_nxt *---* C:\Program Files\BlueStacks_nxt\BlueStacksHelper.exe *---* BlueStacks Helper *---* Enable *---* File not found
GoogleUpdateTaskMachineCore *---* \GoogleUpdateTaskMachineCore *---* C:\Program Files (x86)\Google\Update\GoogleUpdate.exe *---* Keeps your Google software up to date. If this task is disabled or stopped, your Google software will not be kept up to date, meaning security vulnerabilities that may arise cannot be fixed and features may not work. This task uninstalls itself when there is no Google software using it. *---* Disable *---* Google Inc.
GoogleUpdateTaskMachineUA *---* \GoogleUpdateTaskMachineUA *---* C:\Program Files (x86)\Google\Update\GoogleUpdate.exe *---* Keeps your Google software up to date. If this task is disabled or stopped, your Google software will not be kept up to date, meaning security vulnerabilities that may arise cannot be fixed and features may not work. This task uninstalls itself when there is no Google software using it. *---* Disable *---* Google Inc.
MSIAfterburner *---* \MSIAfterburner *---* C:\Program Files (x86)\MSI Afterburner\MSIAfterburner.exe *---* *---* Enable *---* File not found
MSISW_Host *---* \MSISW_Host *---* C:\Windows\SysWOW64\muachost.exe *---* MSI Software Host *---* Enable *---* MSI
NVIDIA App SelfUpdate_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} *---* \NVIDIA App SelfUpdate_{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8} *---* C:\Program Files\NVIDIA Corporation\NVIDIA app\CEF\NVIDIA App.exe *---* *---* Enable *---* NVIDIA Corporation
File Association
Nothing
IFEO
Nothing
IME/CTF
Nothing
Firewall Rule
Nothing
System User Name
Nothing
Scan MBR Rootkit
Nothing
According to your earlier logs there is no VPN Gate connection active while the vpnclient_x64 process is transmitting vast amounts of data. SoftEther is an easy target for malware process injection due to being open source.
Unfortunately PC Hunter without the driver is useless, but its basic service list logs one item of interest:
This thing has no product signature and runs in the system folder! Search suggests that it's from Realtek but why no Realtek signature? Do investigate it. Also try alternative AV scanners.
RunSwUSB *---* Started *---* Automatic *---* C:\Windows\runSW.exe *---* *---* *---* -
goonlord
I checked and it does have a digital signature signed by Realtek when I clicked to view its properties. I tried to disable the service, then enable SoftEther service again, but it changed nothing. I will try to remove this and run the VPN again and see how it goes. Do you have any AV scanners recommendation? I will try to use that if nothing works then I guess I will have to uninstall SoftEther sadly.solo wrote: ↑Tue Jun 18, 2024 11:21 amAccording to your earlier logs there is no VPN Gate connection active while the vpnclient_x64 process is transmitting vast amounts of data. SoftEther is an easy target for malware process injection due to being open source.
This thing has no product signature and runs in the system folder! Search suggests that it's from Realtek but why no Realtek signature? Do investigate it. Also try alternative AV scanners.Code: Select all
Also not sure if related but I noticed that Google has been mass banning public VPN addresses which leads to 403 error on their sites.
This will remove only a symptom of an infection. Try https://duckduckgo.com/?q=rootkit+scanner
goonlord
Alright so I discovered something funny. Apparently my SoftEther folder is 19GB now lol. Most of them are taken up by massive logs, with some going up to 1 GB. I'm going to upload a smaller one for you to see, it's around 100MB. I have found that it's connecting to what seems to be advertisement sites, social media, google api and some gaming site (Nexon). Normal uninstallation method doesn't remove these apparently. So I'm doing a thorough cleanup with Revo Uninstaller and see how it goes. So far Windows Defender (offline, full scan ,malicious software remover), Malwarebytes, and BitDefender (full, rescue mode) didn't detect anything, all of them has rootkit scans AFAIK. I'm going for a Hitman Pro scan as a last resort later on.solo wrote: ↑Tue Jun 18, 2024 8:32 pmThis will remove only a symptom of an infection. Try https://duckduckgo.com/?q=rootkit+scanner
Here's the log. It's in .log format from "C:\Program Files\SoftEther VPN Client\packet_log\VPNGATE" so it should be safe for you.
https://mega.nz/file/kH0kTR5B#uyGQiKHjf ... d5CBi0k1Xk
This is a "VPN Gate Relay Service" log!
Read...
Case closed, LOL
Read...
Why did you do it? Just go: Tools > Switch Operation Mode > VPN Gate Service Settings > Enable the VPN Gate Relay Service and Join the VPN Gate Research as a Volunteer > OFFEnable the VPN Gate Relay Service and Join the VPN Gate Research as a Volunteer.
If you check the above checkbox and press OK, the VPN Gate Relay Service will be activated on this computer. As the result, any VPN Gate Client will be able to communicate towards the Internet via the VPN Gate Relay Service. It is secure even if your computer is on the private network (e.g. corporate network) because any accesses to private IP addresses will not be permitted to pass via the VPN Gate Relay Service.
This will activate the VPN Gate Relay Service function.
After the VPN Gate Relay Service will be enabled and you are participating in the VPN Gate experiment as a volunteer, the VPN Gate Relay Service will relay VPN communications and packets from any VPN Gate clients via the Internet. Therefore, the source IP address of the communication via a VPN tunnel will be replaced to the IP address of the computer running the VPN Gate Relay Service. Since VPN communications are encrypted, the communication between the VPN client and the VPN Gate Relay Service will be able to avoid censorship by government censorship firewalls. The VPN Gate Relay Service runs as a Windows background program, even before the user logs on.
It is assumed that users will use VPN Gate primarily to circumvent censorship; VPN Gate Relay Service records VPN connection logs and packet logs; note that unlike Tor, VPN Gate has no anonymizing effect.
Running the VPN Gate Relay Service and offering it to other VPN Gate users over the Internet has the same technical effect as running Public WiFi at airports, town squares, or other public spaces, etc. As Public WiFi also saves communication logs, the VPN Gate Relay Service does save communication logs. It is stored on the disk of the computer running the VPN Gate Relay Service. Both administrators of VPN Gate Relay Services and VPN users may encounter legal problems as a result of their communications through the VPN Gate Relay Service. In this case, it may be necessary for the administrator of the VPN Gate Relay Service to disclose the communication logs to the police, courts, lawyers, etc. If the administrator is requested or ordered to disclose the logs in accordance with the applicated laws, the administrator is obligated to cooperate lawfully in order to maintain the public safety of the Internet. Please understand the above before activating the VPN Gate Relay Service.
VPN Gate Relay Service function must be activated by your own risk.
Some countries prohibit using of encrypted VPN by laws.
For more details about VPN Gate Relay Service please visit http://www.vpngate.net/en/join.aspx.
The VPN Gate Academic Experiment Service is operated as a research project at the graduate school on University of Tsukuba, Japan. The service is governed under the Japanese laws. Other countries' laws are none of our concerns nor responsibilities.
By nature, there are almost 200 countries in the World, with different laws. It is impossible to verify every countries' laws and regulations and make the software comply with all countries' laws in advance to release the software. If a user uses VPN Gate service in a specific country, and damaged by public servants of the authority, the developer of either the service or software will never be liable to recover or compensate such damages or criminal responsibilities. By using this software and service, the user must observe all concerned laws and rules with user's own responsibility. The user will be completely liable to any damages and responsibilities which are results of using this software and service, regardless of either inside or outside of Japan's territory. VPN Gate Relay Service will be installed on your computer as system services. System services always run in the background. After you terminate these management GUI tools, this system service will continue to run in the background. System services consume CPU time, computer power, memory and disk space. If you don't agree nor understand the above warnings, do not use any of VPN Gate Academic Experiment Service functions.
Case closed, LOL
goonlord
Now this is awkward, because I cleaned it with Revo Uninstaller, reinstalled the latest version and did not tick the box and and yeah, it's fixed lol. It's probably ticked by default on the older version or something. Does activating it means I just turned myself into a VPN server?solo wrote: ↑Wed Jun 19, 2024 7:43 pmThis is a "VPN Gate Relay Service" log!
Read...Why did you do it? Just go: Tools > Switch Operation Mode > VPN Gate Service Settings > Enable the VPN Gate Relay Service and Join the VPN Gate Research as a Volunteer > OFFEnable the VPN Gate Relay Service and Join the VPN Gate Research as a Volunteer.
Case closed, LOL
Anyway thanks a lot for the help and follow up you provided, really appreciate it.
