Static Routing Table Pushing Function is NO,
saifu.k
Post by saifu.k » Thu Jun 20, 2024 5:40 am
Ubuntu instance i installed softether vpn, but some feature not supported in Saudi region
The static routing table to push service is off
Please advise the solutions
Re: Static Routing Table Pushing Function is NO,
Post by solo » Thu Jun 20, 2024 7:49 am
Either use the official build or replace SecureNAT with dnsmasq+iptables.
saifu.k
Post by saifu.k » Tue Jul 02, 2024 11:46 am
Still the same i have user official build version,
Could you please help me to do the next option "replace SecureNAT with dnsmasq+iptables"
Post by solo » Tue Jul 02, 2024 12:44 pm
You are doing something wrong, look:
https://www.vpnusers.com/search.php?key ... 2Biptables
saifu.k
Post by saifu.k » Wed Jul 03, 2024 12:46 am
I am doing following this https://www.digitalocean.com/community/ ... -softether and its working other regions except Saudi.
i tried Ubuntu and Centos Different version, but its same.
Post by solo » Wed Jul 03, 2024 5:53 am
While still on the official build...
stop the server
edit vpn_server.config
	declare DDnsClient
		bool Disabled true
start the server
check status of "Static Routing Table Pushing Function"
saifu.k
Post by saifu.k » Wed Jul 03, 2024 10:47 am
Thank you .... Its working now..
