Hello
Need help.
I am trying to run SoftEther VPN Client, but unfortunately I am getting an error: "Unable to connect to the VPN Client service operating on Local Computer. Make sure the VPN Client service has started and is running normally".
I verified that the service named SEVPNCLIENT cannot start. It returns error 1067, repeatedly.
I have deleted the entire application, files, vrtual network adapter, tried deleting res registers, nothing helps.
Can you advise what to do?
Best Regards
Softether VPN Client - Service error 1067
Golima
Re: Softether VPN Client - Service error 1067
I saw this and it didn't help solve the problem.
"C:\WINDOWS\system32\drivers\Neo_*.sys"
"[-HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Neo_VPN]
[-HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SEVPNCLIENT]"
The one above wasn't even in the registry, nor was this driver.
And in Safe Boot mode I couldn't install the application.
This is not a SoftEther's issue, check Windows support forums or https://duckduckgo.com/?q=Error%201067% ... expectedly
