Unable to import my generated certificate to Android
hector9
Post by hector9 » Tue Jul 09, 2024 7:20 am
Hi, I can't import my generated certificate into Android after upgrading to SoftEther VPN 4.0.
Android asks me for a password to import the .P12 file, but with or without the password it won't accept it.
Does anyone know what the error is and how to fix it? Thank.
B0GDAN
Re: Unable to import my generated certificate to Android
Post by B0GDAN » Sat Oct 19, 2024 5:31 pm
Anyone?
Post by solo » Sun Oct 20, 2024 12:09 am
Don't use the default certificate store.
Specify Trusted Certificates (SSL Layer)
If you choose a certain directory, the client uses ONLY certificates in the directory, but the default certificate store. I made this option for debugging. This preference is displayed as Add Trusted Certificates in v1.7.0 or older. Your device needs to install a self-signed certificate and disable Verify Hostname option to access to a server using it
https://github.com/kittoku/Open-SSTP-Client
Otherwise, create a PFX certificate for that device.
