quattrolinux
Post
by quattrolinux » Sat Aug 03, 2024 3:12 am
OPTIONS ERROR: failed to negotiate cipher with server. Add the server's cipher ('AES-128-CBC') to --data-ciphers (currently 'AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305') if you want to connect to this server.
From the manual:
2.4.x or lower: The cipher in --cipher is appended to --data-ciphers.
Question: how do I change server cipher from AES-128-CBC to one of openvpn 2.6.x default ciphers?
Post
by solo » Sat Aug 03, 2024 8:42 am
1. update to v5 DE server
2. select your preferred "Encryption Algorithm Name" on the server
3. always enter algo name in ovpn "data-ciphers"
spp
Post
by spp » Fri Jan 03, 2025 3:39 pm
Edit your config manually.
in openvpn-2.4.x should use --ncp-ciphers
in openvpn-2.5.x-2.6.x should use --data-ciphers
default cipher in latest openvpn is AES-256-GCM and AES-128-GCM
Note: softether not yet supported cipher negotiation introduced in openvpn-2.4 therefore only one cipher available.
