SSTP Slow Speed
adroman
SSTP Slow Speed
Post by adroman » Mon Sep 02, 2024 1:29 pm
Guys, I've encountered that SSTP speed is really slow like only 100-130 mbps download
I'm using Mikrotik SSTP client
Is SSTP slower than other protocols like wireguard and openvpn or something wrong with my config?
Is there any best practices to improve SSTP speed?
Re: SSTP Slow Speed
Post by solo » Tue Sep 03, 2024 2:00 am
Run TrafficClient speed test: vpncmd /tools /cmd TrafficClient speed.softether.com:9821
#1 TrafficClient from your VPN server to the speed server
#2 TrafficClient from a SoftEther VPN client to the speed server
#3 TrafficClient from the client's PC directly to the speed server
#4 TrafficClient from a LAN PC via Mikrotik SSTP to the speed server
Post AS CODE these four stats exactly as follows:
Example of #1
Average Throughput in Download Direction              |  1,128,980,684 bps|      1.13 Gbps
Average Throughput in Upload Direction                |  1,139,082,463 bps|      1.14 Gbps
