WORKING solution for VPN and Samba on same Linux host (tutorial inside)
autobottodoggo
Post by autobottodoggo » Thu Sep 05, 2024 2:23 pm
Every time I've attempted to search for this, the answers have always come up short and incomplete. So I finally buckled down and created a guide for myself.
First, some assumptions:
  • you already have SEVPN server installed, configured, and running on the Linux host
  • you already have SEVPN client installed, configured, and running on a remote system (any compatible OS)
  • you are familiar with the SEVPN admin server manager GUI
  • you are familiar with Linux and bash CLI
  • you are familiar with with the basic concepts of TCP/IP
This guide was specifically written for RHEL CentOS/RockyOS, but it can be adapted for other distros.
STEP-BY-STEP TUTORIAL
# install bridge-utils from repo if available
# use applicable package manager for OS (eg.: `apt` on Debian-based systems)
yum install bridge-utils.x86_64
# if bridge-utils not available from repo, you'll need to download and compile it...
# compiler pre-reqs
yum update -y
yum -y install epel-release wget
yum groupinstall 'Development Tools' -y
# download, compile, and install bridge-utils
cd bridge-utils
git clone -b main git://git.kernel.org/pub/scm/network/bridge/bridge-utils.git
autoconf
./configure
make
make install
# start VPN server here
# open the SEVPN GUI on a networked system, create hub, users, etc.
# create the virtual bridge NIC
# sub 'br0' with appropriate device name (can be anything with letters, numbers, underscores, and hyphens)
brctl addbr br0
# bind virtual bridge to physical NIC (sub 'eth0' with name of physical NIC)
brctl addif br0 eth0
# edit: /etc/sysconfig/network-scripts/ifcfg-br0
# (sub 'br0' with name of virtual NIC)
# replace IP configs with whatever is correct for your network
DEVICE=br0
TYPE=Bridge
BOOTPROTO=none
ONBOOT=yes
DELAY=0
NAME=br0
IPADDR="192.168.x.x"
PREFIX="24"
GATEWAY="192.168.x.x"
DNS1="192.168.x.x"
# edit: /etc/sysconfig/network-scripts/ifcfg-eth0
# (sub 'eth0' with name of physical NIC)
# remove or comment out IP config lines and add:
BRIDGE="br0"
# bring up the virtual NIC
ip link set br0 up
# return to SEVPN GUI on a networked system
# delete any existing bridges
# create new bridge on virtual hub and select the *physical* NIC as destination
# reboot VPN host to confirm persistence
reboot
# after reboot, confirm connections...
# should show IP on virtual NIC, and *no* IP on physical NIC
ipconfig
# should show at minimum: lo, physical NIC, virtual NIC
ip link
# should return positive ping response
ping $your_gateway_IP
ping 8.8.8.8
# on VPN client: should be able to mount and navigate SMB shares on VPN host
Re: WORKING solution for VPN and Samba on same Linux host (tutorial inside)
Post by solo » Fri Sep 06, 2024 12:08 am
autobottodoggo wrote: ↑
This is because of variety of scenarios requiring different solutions. Your proposition barely scratches the surface.
spp
Post by spp » Thu Jan 02, 2025 9:10 pm
In most linux distros, the ethernet brigde may be configured with systemd
First, create a bridge:
/etc/systemd/network/1-br0.netdev
[NetDev]
Name=br0
Kind=bridge
/etc/systemd/network/1-br0.network
[Match]
Name=br0
[Network]
ConfigureWithoutCarrier=true
Address=192.168.45.1/24
Also create a tap device(s) included to the bridge
/etc/systemd/network/2-tap_soft.netdev
[NetDev]
Name=tap_soft
Kind=tap
/etc/systemd/network/2-tap_soft.network
[Match]
Name=tap_soft
[Network]
Bridge=br0
then apply this configuration
systemctl restart systemd-networkd
and enable load on startup (if disabled)
systemctl enable systemd-networkd
then run vpncmd and configure Softether VPN to use the existing tap_soft device
VPN Server>BridgeCreate DEFAULT /DEVICE:soft /TAP:yes
Any local servers binded to br0 device will be accessible through VPN
