I am having problems with using a SE client on our work network going through a SonicWall TZ 500 router firewall used on the network to connect to the internet. I am testing SE in a backwards setup with the SE server on my home network and remote clients testing access to VMs running on a Proxmox server. Next step would be to move the Proxmox server to the work network and have SE support remote access to all the VM's running on the Proxmox server.
But first I need to determine how to pass SSL VPN packets through the SonicWall. I am using a DDNS to route SE clients to the SE server and this works until I try with SonicWall in the path. The SE server is behind a StarLink router, but no problem here. Has anyone worked with SonicWall Appliances and has a solution to getting packets through?
SoftEther Client through SonicWall TZ 500
Re: SoftEther Client through SonicWall TZ 500
https://www.sonicwall.com/support/knowl ... 3477349850CAUTION: The SonicWall security appliance is managed by HTTP (Port 80) and HTTPS (Port 443), with HTTPS Management being enabled by default. If you are using one or more of the WAN IP Addresses for HTTP/HTTPS Port Forwarding to a Server then you must change the Management Port to an unused Port, or change the Port when navigating to your Server via NAT or another method.
