Secure NAT static Routing not working on azure
saifu.k
Post by saifu.k » Fri Sep 27, 2024 8:00 am
Dear All,
Without Secure NAT default gateway address, its not communicating local network on Azure, Attached screenshot. Please note that with gateway address its communicating but the public IP is changing. And other Cloud provider like AWS is working without Secure NAT default gateway address.
Please help me to resolve this issue.
Re: Secure NAT static Routing not working on azure
Post by solo » Fri Sep 27, 2024 8:54 am
You need a split tunnel.
saifu.k
Post by saifu.k » Fri Sep 27, 2024 11:19 am
Dear Solo,
Thank you for your prompt assistance. I've tried the solutions you suggested(https://www.vpnusers.com/viewtopic.php? ... 16&#p97816), but unfortunately, the issue persists. Could you please provide a step-by-step guide. I've attached a screenshot of my setup for your reference
Thank you,
Saifu
Post by solo » Fri Sep 27, 2024 1:02 pm
The 192.168... push mask appears incorrect.
saifu.k
Post by saifu.k » Fri Sep 27, 2024 1:07 pm
Could you please advice push mask, below the network
eth0: flags=4419<UP,BROADCAST,RUNNING,PROMISC,MULTICAST> mtu 1500
inet 192.168.0.9 netmask 255.255.192.0 broadcast 192.168.63.255
inet6 fe80::6245:bdff:fe14:a7bd prefixlen 64 scopeid 0x20<link>
ether 60:45:bd:14:a7:bd txqueuelen 1000 (Ethernet)
RX packets 244819 bytes 64504978 (64.5 MB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 318426 bytes 89447810 (89.4 MB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 1 bytes 76 (76.0 B)
TX packets 1 bytes 76 (76.0 B)
Post by solo » Fri Sep 27, 2024 1:27 pm
The "inet 192.168.0.9 netmask 255.255.192.0 broadcast 192.168.63.255" config appears incorrect.
saifu.k
Post by saifu.k » Fri Sep 27, 2024 4:29 pm
Its the config of Azure VM
Post by solo » Sat Sep 28, 2024 12:45 am
Push this: 192.168.64.0/255.255.192.0/192.168.30.1
saifu.k
Post by saifu.k » Sat Sep 28, 2024 3:38 pm
Dear Solo,
I just wanted to let you know that everything is working perfectly. Thank you so much for your help—it's truly appreciated!
Warm regards,
Saifu.
