VPN Network slow speed
Steve_Dxb
Post by Steve_Dxb » Wed Oct 09, 2024 8:29 am
Hi Team,
I hosted my softether server in Aws Mumbai region ( Speed : 701.83 Mbps / 547.70 Mbps ) , and I configured the softether vpn client in other pc which is located outside India with client system speed of 300Mbps/120Mbps. While I connected to the softether VPN , the client system speed will reduce to 2Mbps/1.5 Mbps. I dont know what the issue is, I tried to disable the SecureNat, but when I do that the network showing local IP.
Kindly advice.
Re: VPN Network slow speed
Post by solo » Wed Oct 09, 2024 8:56 am
Hi, reveal your OS and VPN protocol used, then post TrafficClient stats.
vpncmd /tools /cmd TrafficClient speed.softether.com:9821
#1 TrafficClient from your VPN server to the speed server
#2 TrafficClient from a VPN client to the speed server
#3 TrafficClient from the client's PC directly to the speed server
Include CPU usage on your VPN server before and during tests #1 and #2
Example of #1
Average Throughput in Download Direction              |  1,128,980,684 bps|      1.13 Gbps
Average Throughput in Upload Direction                |  1,139,082,463 bps|      1.14 Gbps
CPU idle 1%
CPU peak 16%
