SoftEther SSTP spontaneous consumption of 100% CPU
Anna_K
I am using:
debian 12
SoftEther VPN Server (Ver 4.42, Build 9798, rtm)
config SoftEther VPN:
> SecureNatEnable
> SstpEnable yes
> KeepDisable
> SetEnumDeny
> ListenerCreate 43001
> ListenerDelete 5555
> ListenerDelete 443
> DhcpSet /START:192.168.30.12 /END:192.168.30.200 /MASK:255.255.255.0 /EXPIRE:7200 /GW:192.168.30.1 /DNS:1.0.0.1 /DNS2:1.1.1.1 /DOMAIN:none /LOG:yes /PUSHROUTE:none
There are only 3 users
the program spontaneously consumes 100% of the CPU at different intervals. CPU consumption lasts for 20-30 minutes and then stops
I checked the traffic movement at this point in time, no, I even turned off all clients for CPU consumption continued. ports are not strange, it's not hackers who will hack them. everything is fine in the logs and there are no problems.
Where is the problem why is the program consuming CPU?
debian 12
> SecureNatEnable
> SstpEnable yes
> KeepDisable
> SetEnumDeny
> ListenerDelete 5555
> ListenerDelete 443
Re: SoftEther SSTP spontaneous consumption of 100% CPU
Try viewtopic.php?f=7&t=68546#p100051
If unresolved, report it on Github.
Anna_K
changing the parameter DisableIpRawModeSecureNAT did not help.
I think you need to delete the old 4th version and install the new 5th version.
I'll write later when I compile a new version and observe for a few days
Anna_K
Upgrading from version 4 to version 5 does not help. Both versions have the problem.
SoftEther VPN Server 4.42, Build 9798
SoftEther VPN Server 5.02.5187
There is a problem in the source code of both versions, it needs to be fixed. How can I help solve the problem?
Anna_K
there is already a similar problem on the github website https://github.com/SoftEtherVPN/SoftEth ... ssues/2000
the problem arose back in May of this year (5 months ago).
and the 5th version is being discussed on the github website. you are discussing the 4th version. I am ready to help both projects.
Very well, please disable SecureNAT and replicate its functionality with dnsmasq and iptables.
Anna_K
using SecureNat for me is more of an advantage, I really don't want to turn off this function. and in addition I need help and instructions on how to replace SecureNat through the built-in dnsmasq and iptables in debian 12.
Anna_K
disabling SecureNAT will disable all clients completely, no user will be able to connect. You want to test a simply working server without clients and without traffic. Do I understand you correctly?
It's hard for me to do this. You have to wait until the weekend. You can't just turn off all clients on weekdays. Please wait until the end of the week.
Anna_K
I approximately understood where the problem was. At the beginning of viewing sites through this VPN and with a large load, many connections are opened and it seems to be buggy there. The test was held on Mikrotik routers (there were 4 different versions of routers). If you look at the site simply and slowly, everything is good, but with the fast leaflet of the Facebook tape, for example, a noble load on a router occurs up to 100% within 30 minutes. The load continues to remain 100% even after the client is disconnected from VPN
Which means that the no-SecureNAT test must involve active connections. Disable SecureNAT and bridge the hub to a soft tap search.php?keywords=soft+tap
At this point SoftEther's role ends and common Linux setup starts. We don't offer OS guides nor support its issues, but the setup had been extensively discussed before:
search.php?keywords=iptables
search.php?keywords=dnsmasq
BTW "dnsmasq vs SecureNAT" viewtopic.php?f=7&t=67986&p=97671#p97671
It's better anyway.
It's better anyway.
