Add a route for VPN Connection (Windows)
TheColonel26
Post by TheColonel26 » Thu Oct 17, 2024 2:33 pm
I need to access another network that is on the other side of my VPN connection.
So I connect in to the VPN which is on 1 subnet 192.168.33.0 then I need to connect to other networks that are 10.110.101.0 and 10.110.102.0.
So I would like to add a route to my route table when ever I connect to that VPN gateway. The route would be to route all 10.110.0.0 traffic to 192.168.33.0
Can softether do this automatically when it connects?
Re: Add a route for VPN Connection (Windows)
Post by solo » Fri Oct 18, 2024 1:10 am
On the server in SecureNAT "Edit the static routing table to push" and start the "Routing and Remote Access" service.
