VPN Azure Problem
serak
VPN Azure Problem
Post by serak » Wed Dec 11, 2024 9:27 am
I've been having trouble connecting with Azure VPN for a few days now. VPN Azure only seems to work for part of the day. Although pinging to userxyz.vpnazure.net works the whole day, the vpnserver shows that vpnazure is not connected most of the day.
This happens at the same time every day. Is it possible that the service has been deactivated for a specific time during the day?
Re: VPN Azure Problem
Post by solo » Thu Dec 12, 2024 1:24 am
It could be your userxyz server intermittently faulty. In any case don't rely on the free Azure with low bandwidth and high latency VPN from JP location. Consider a cheap local VPS instead viewtopic.php?f=7&t=68180#p98572
