Strange IP/Azure/softether.net conectivity...
mendoza_lt
Post by mendoza_lt » Thu Dec 12, 2024 6:11 pm
I have set up softethervpn in router. It is behind another "Main" router. I prefer to use IP address (public/private ip combination) to connect to it, because neither vpnazure nor softether.net is guaranteed, and no one can take IP addresses from me. But... If i set WAN IP address on the VPN router to DHCP - i can connect to it using public/private IP combination. And if i set it manually, same settings (except ip, of course), - i can not connect to the router. Only vpnazure works... what could be the reason?
Re: Strange IP/Azure/softether.net conectivity...
Post by solo » Fri Dec 13, 2024 12:59 am
mendoza_lt wrote: ↑
On OpenWrt firmware? Post as code when on DHCP...
ifconfig
ip addr
route -n
ip route
traceroute 1.1.1.1
...and again on manual IP.
mendoza_lt
Post by mendoza_lt » Fri Dec 13, 2024 5:46 am
That's OpenWrt based Teltonika RUTX09, Here are the logs:
eth1.50 is a management Vlan for openwisp...
Static:
root@RUTX09:~# ifconfig
eth1      Link encap:Ethernet  HWaddr 20:97:27:07:7F:57
          inet addr:192.168.88.8  Bcast:192.168.88.255  Mask:255.255.255.0
          inet6 addr: fe80::2297:27ff:fe07:7f57/64 Scope:Link
          UP BROADCAST RUNNING PROMISC MULTICAST  MTU:1500  Metric:1
          RX packets:1015929 errors:0 dropped:120 overruns:0 frame:0
          TX packets:68131 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:213650449 (203.7 MiB)  TX bytes:5511964 (5.2 MiB)
eth1.50   Link encap:Ethernet  HWaddr 20:97:27:07:7F:57
          inet addr:192.168.50.2  Bcast:192.168.50.255  Mask:255.255.255.0
          RX packets:25720 errors:0 dropped:0 overruns:0 frame:0
          TX packets:14623 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1649063 (1.5 MiB)  TX bytes:928338 (906.5 KiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:777166 errors:0 dropped:0 overruns:0 frame:0
          TX packets:777166 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:65934527 (62.8 MiB)  TX bytes:65934527 (62.8 MiB)
root@RUTX09:~# ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,PROMISC> mtu 1500 qdisc noop state DOWN group default qlen 1000
    link/ether 20:97:27:07:7f:56 brd ff:ff:ff:ff:ff:ff
3: eth1: <BROADCAST,MULTICAST,PROMISC,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether 20:97:27:07:7f:57 brd ff:ff:ff:ff:ff:ff
    inet 192.168.88.8/24 brd 192.168.88.255 scope global eth1
    inet6 fe80::2297:27ff:fe07:7f57/64 scope link
4: ip6tnl0@NONE: <NOARP> mtu 1452 qdisc noop state DOWN group default qlen 1000
    link/tunnel6 :: brd :: permaddr 6eae:a6da:7cb8::
5: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1000
    link/sit 0.0.0.0 brd 0.0.0.0
6: gre0@NONE: <NOARP> mtu 1476 qdisc noop state DOWN group default qlen 1000
    link/gre 0.0.0.0 brd 0.0.0.0
7: gretap0@NONE: <BROADCAST,MULTICAST> mtu 1462 qdisc noop state DOWN group default qlen 1000
    link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
8: erspan0@NONE: <BROADCAST,MULTICAST,PROMISC> mtu 1450 qdisc noop state DOWN group default qlen 1000
9: ip6gre0@NONE: <NOARP> mtu 1448 qdisc noop state DOWN group default qlen 1000
    link/gre6 :: brd :: permaddr 8ad8:3618:4f90::
10: miireg: <> mtu 0 qdisc noop state DOWN group default qlen 1000
    link/netrom
11: wwan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
    link/ether 82:66:c6:2b:bb:1c brd ff:ff:ff:ff:ff:ff
12: eth1.50@eth1: <BROADCAST,MULTICAST,PROMISC,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    inet 192.168.50.2/24 brd 192.168.50.255 scope global eth1.50
root@RUTX09:~# route -n
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         192.168.88.1    0.0.0.0         UG    1      0        0 eth1
192.168.50.0    0.0.0.0         255.255.255.0   U     0      0        0 eth1.50
192.168.88.0    0.0.0.0         255.255.255.0   U     1      0        0 eth1
root@RUTX09:~# ip route
default via 192.168.88.1 dev eth1 proto static metric 1
192.168.50.0/24 dev eth1.50 proto kernel scope link src 192.168.50.2
192.168.88.0/24 dev eth1 proto static scope link src 192.168.88.8 metric 1
root@RUTX09:~# traceroute 1.1.1.1
traceroute to 1.1.1.1 (1.1.1.1), 30 hops max, 46 byte packets
 1  192.168.88.1 (192.168.88.1)  0.028 ms  0.030 ms  0.026 ms
 2  81.191.29.1 (81.191.29.1)  1.711 ms  1.353 ms  1.559 ms
 3  ae25.cr2.fn3.as2116.net (195.0.242.230)  0.909 ms  0.894 ms  0.797 ms
 4  ae12.br2.fn3.as2116.net (193.75.2.51)  0.452 ms  0.440 ms  0.445 ms
 5  162.158.220.2 (162.158.220.2)  2.550 ms  0.921 ms  1.059 ms
 6  one.one.one.one (1.1.1.1)  0.402 ms  0.650 ms  0.662 ms
DHCP:
ifconfig
          inet addr:192.168.88.130  Bcast:192.168.88.255  Mask:255.255.255.0
          RX packets:1033436 errors:0 dropped:120 overruns:0 frame:0
          TX packets:69570 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:216485429 (206.4 MiB)  TX bytes:6286711 (5.9 MiB)
          RX packets:25993 errors:0 dropped:0 overruns:0 frame:0
          TX packets:14779 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1666379 (1.5 MiB)  TX bytes:938322 (916.3 KiB)
          RX packets:785511 errors:0 dropped:0 overruns:0 frame:0
          TX packets:785511 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:66701471 (63.6 MiB)  TX bytes:66701471 (63.6 MiB)
    inet 192.168.88.130/24 brd 192.168.88.255 scope global eth1
    link/netrom
default via 192.168.88.1 dev eth1 proto static src 192.168.88.130 metric 1
192.168.88.0/24 dev eth1 proto static scope link src 192.168.88.130 metric 1
 1  192.168.88.1 (192.168.88.1)  0.302 ms  0.258 ms  0.228 ms
 2  81.191.29.1 (81.191.29.1)  7.306 ms  11.713 ms  4.611 ms
 3  ae25.cr2.fn3.as2116.net (195.0.242.230)  0.880 ms  0.954 ms  1.000 ms
 4  ae12.br2.fn3.as2116.net (193.75.2.51)  0.476 ms  0.523 ms  0.496 ms
 5  162.158.220.2 (162.158.220.2)  47.465 ms  1.283 ms  1.224 ms
 6  one.one.one.one (1.1.1.1)  0.608 ms  0.619 ms  0.600 ms
root@RUTX09:~#
Post by solo » Fri Dec 13, 2024 5:56 am
On your "Main" router ensure that the VPN port is forwarded only to 192.168.88.8 and remove any other erroneous entries.
mendoza_lt
Post by mendoza_lt » Fri Dec 13, 2024 4:49 pm
Yeah, i thought about "main" router, when i analyzed logs, but the thing is that i do not have access to it, that is one of the reasons Softether was used. I guess i will have to live with like it is now...
