hello.
japan IP ( wan ip : 1.1.1.1/25 or other ip ) ---> Datacenter -> switch -> Server ( server pc ip : 1.1.1.20 ) , ( server pc2 ip : 1.1.1.21 )
I want to configure it like this.
Using the actual Japan IP ( 1.1.1.20 )
You must use Japan IP, and set Japan IP on the server.
I looked it up
They say you just need to configure a softether VPN server and a softether VPN bridge.
I'm having a hard time because I don't have an accurate guide.
Is there anyone who can help?
The configuration must be configured in bridge mode.
hello. I want to get my IP through VPN.
