So I'm using SoftEther with VPNGate, is there anyway to filter or only allow specific apps to use the vpn?
Like can I only allow chrome to use the vpn and meanwhile firefox stays on my real connection?
SoftEther - How to only allow specific apps to use vpn?
droop
Re: SoftEther - How to only allow specific apps to use vpn?
Try ForceBindIP or a proxy.
brendag
You can use ForceBindIP to bind specific apps to the VPN, or set up application-specific rules if your VPN client supports it. Alternatively, configuring a proxy for certain apps is another effective solution!
