How to make only a single program
dung1412
i use windows 11 and Softehter VPN 4.0, i need use VPN for only a single program (Ex: game), when i check No Adjustments of Routing Table then show unacceptable operation. use the VPN Gate Utility to modify the connection setting for VPN Gate Public VPN relay servers. Please help me.
Re: How to make only a single program
Leave "No Adjustments Of Routing Table" unchecked and modify routing as follows.
connect to (eg.) public-vpn-222
0.0.0.0 0.0.0.0 10.244.254.254 10.244.10.60 1
10.0.3.0 255.255.255.0 10.0.3.15 10.0.3.15 10
10.0.3.15 255.255.255.255 127.0.0.1 127.0.0.1 10
10.244.0.0 255.255.0.0 10.244.10.60 10.244.10.60 1
10.244.10.60 255.255.255.255 127.0.0.1 127.0.0.1 1
10.255.255.255 255.255.255.255 10.0.3.15 10.0.3.15 10
10.255.255.255 255.255.255.255 10.244.10.60 10.244.10.60 1
127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1
130.158.6.60 255.255.255.255 10.0.3.2 10.0.3.15 10
219.100.37.184 255.255.255.255 10.0.3.2 10.0.3.15 1
route delete 0.0.0.0 10.244.254.254
route add 0.0.0.0 mask 0.0.0.0 10.0.3.2
route add 8.8.8.8 mask 255.255.255.255 10.244.254.254
//where 8.8.8.8 is a "single program"
0.0.0.0 0.0.0.0 10.0.3.2 10.0.3.15 1
8.8.8.8 255.255.255.255 10.244.254.254 10.244.10.60 1
tracert 8.8.8.8
1 219 ms 243 ms 237 ms public-nat-out.vpngate.open.ad.jp [10.244.254.254]
2 292 ms 259 ms 373 ms gw2.vpngate.v4.open.ad.jp [219.100.37.253]
3 260 ms 246 ms 276 ms igp1.green.v4.open.ad.jp [202.222.12.190]
4 235 ms 220 ms 208 ms bgp3.openospf1.v4.open.ad.jp [202.222.12.33]
5 282 ms 271 ms 271 ms 150.99.184.33
6 282 ms 216 ms 210 ms 150.99.10.187
7 317 ms 237 ms 299 ms 210.173.176.243
8 241 ms 219 ms 218 ms 108.170.231.103
9 385 ms 217 ms 297 ms 74.125.251.235
10 251 ms 339 ms 276 ms dns.google [8.8.8.8]
dung1412
can you help me take picture step and step follows this tips, i don't make it huhu, thank you so much for help me.solo wrote: ↑Sun Feb 23, 2025 1:53 amLeave "No Adjustments Of Routing Table" unchecked and modify routing as follows.
connect to (eg.) public-vpn-222 Network Destination Netmask Gateway Interface Metric 0.0.0.0 0.0.0.0 10.244.254.254 10.244.10.60 1 10.0.3.0 255.255.255.0 10.0.3.15 10.0.3.15 10 10.0.3.15 255.255.255.255 127.0.0.1 127.0.0.1 10 10.244.0.0 255.255.0.0 10.244.10.60 10.244.10.60 1 10.244.10.60 255.255.255.255 127.0.0.1 127.0.0.1 1 10.255.255.255 255.255.255.255 10.0.3.15 10.0.3.15 10 10.255.255.255 255.255.255.255 10.244.10.60 10.244.10.60 1 127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1 130.158.6.60 255.255.255.255 10.0.3.2 10.0.3.15 10 219.100.37.184 255.255.255.255 10.0.3.2 10.0.3.15 1 route delete 0.0.0.0 10.244.254.254 route add 0.0.0.0 mask 0.0.0.0 10.0.3.2 route add 8.8.8.8 mask 255.255.255.255 10.244.254.254 //where 8.8.8.8 is a "single program" Network Destination Netmask Gateway Interface Metric 0.0.0.0 0.0.0.0 10.0.3.2 10.0.3.15 1 8.8.8.8 255.255.255.255 10.244.254.254 10.244.10.60 1 10.0.3.0 255.255.255.0 10.0.3.15 10.0.3.15 10 10.0.3.15 255.255.255.255 127.0.0.1 127.0.0.1 10 10.244.0.0 255.255.0.0 10.244.10.60 10.244.10.60 1 10.244.10.60 255.255.255.255 127.0.0.1 127.0.0.1 1 10.255.255.255 255.255.255.255 10.0.3.15 10.0.3.15 10 10.255.255.255 255.255.255.255 10.244.10.60 10.244.10.60 1 127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1 130.158.6.60 255.255.255.255 10.0.3.2 10.0.3.15 10 219.100.37.184 255.255.255.255 10.0.3.2 10.0.3.15 1 tracert 8.8.8.8 1 219 ms 243 ms 237 ms public-nat-out.vpngate.open.ad.jp [10.244.254.254] 2 292 ms 259 ms 373 ms gw2.vpngate.v4.open.ad.jp [219.100.37.253] 3 260 ms 246 ms 276 ms igp1.green.v4.open.ad.jp [202.222.12.190] 4 235 ms 220 ms 208 ms bgp3.openospf1.v4.open.ad.jp [202.222.12.33] 5 282 ms 271 ms 271 ms 150.99.184.33 6 282 ms 216 ms 210 ms 150.99.10.187 7 317 ms 237 ms 299 ms 210.173.176.243 8 241 ms 219 ms 218 ms 108.170.231.103 9 385 ms 217 ms 297 ms 74.125.251.235 10 251 ms 339 ms 276 ms dns.google [8.8.8.8]
